Toymods » Tech & Conversions » Bolt-in tachometer question
cleong
March 2005
Bolt-in tachometer question Wed, 31 August 2005 09:51 Go to next message
I'm looking at installing a tachometer for my AE92 Corolla CS. It has a 4A-FC engine (the carby one).
So I found this tachometer on ebay but it has a clause:
Do Not Fit Coil Pack Car Like V6 Commodore/Hyundia?Lancers ect WithOut Special Control Box Which Is $150 From Rocket Industries FITS ALL CARS WITH A DISTRIBTOR POINTS OR ELECTRONIC ALSO HAS A SWITCH ON THE BACK TO FIT ALL 4/6/8 CYLINDERS
So would this work on my car? TIA
In addition I hope to install it into the dashboard of the existing cluster (knock a round blanking plate out and sit the tacho in). Anyone does this before, or should I just mount it on the steering column? I'm not interested in adding racy gauges to the car, just want to know what RPMs its doing.
wilbo666
Re: Bolt-in tachometer question Wed, 31 August 2005 10:00 Go to previous messageGo to next message
You car does not use coil packs, (you have a conventional igniter/coil arrangement).
The tacho should work fine Smile
Re: Bolt-in tachometer question Thu, 01 September 2005 11:03 Go to previous messageGo to next message
I really must ask why you'd fit a tacho to a 4AF, but anyway...
Smokey228
January 2005
Re: Bolt-in tachometer question Thu, 01 September 2005 11:23 Go to previous messageGo to next message
cleong wrote on Wed, 31 August 2005 19:51
cleong
March 2005
Re: Bolt-in tachometer question Tue, 06 September 2005 12:32 Go to previous messageGo to next message
Happy ending. I found a complete cluster at a scrapyard for $40. Smile Works a treat, and reads more accurately than the old one. The next problem is bringing the idle speed down from 1000rpm......
hurricane
geelong
August 2005
Re: Bolt-in tachometer question Tue, 06 September 2005 12:41 Go to previous messageGo to next message
turning the car off will drop it Very Happy too 0 Laughing
sorry dont really know alot about how you can do it.
cleong
March 2005
Re: Bolt-in tachometer question Tue, 06 September 2005 15:03 Go to previous message
Definitely. I thought about doing that, but I reckon I have enough time on my hands to start fiddling around tracing the vacuum leak as well as try to play around with the idle screw a little. Who wants a simple solution to a simple problem when you got the spare time to find a complex solution?
[Updated on: Tue, 06 September 2005 15:11]
Previous Topic:Cutch size for the 4AGE 20v?
Next Topic:4AGZE Conversion help
Current Time: Sun Oct 25 00:39:23 UTC 2026
Total time taken to generate the page: 0.0045089721679688 seconds
