Toymods » Tech & Conversions » Air/fuel Ratio Sensor
ta2272
Air/fuel Ratio Sensor Wed, 31 August 2005 10:59 Go to next message
I am getting a wolf 3d v3 computer and was wondering if you can wire, the 4 wire type of sensor is wirable to the wolf, is there 4 wires which have to go to the computer??
Jason
Re: Air/fuel Ratio Sensor Wed, 31 August 2005 11:42 Go to previous messageGo to next message
only 1 wire goes to the ECU (i think). the others are the signal earth (maybe ECU earth), and then power and diferent earth for the heater
ta2272
Re: Air/fuel Ratio Sensor Wed, 31 August 2005 11:54 Go to previous messageGo to next message
So what are the 4 wire one's and all the wire's do
1) Earth
2) ECU Wire
3)
4)
Re: Air/fuel Ratio Sensor Wed, 31 August 2005 12:16 Go to previous messageGo to next message
ta2272 wrote on Wed, 31 August 2005 21:54
1) SIGNAL Earth needs to be clean w/r ECU
2) ECU Wire
3) switched power from IGN? i used fuel pump power.. takes up to 5A when cold, 1A when hot
4) heater earth, just needs to be away from ECU earth and capable of 5 amps.
heater wiring needs to be capable of 5 amps. and make sure it is switched
ta2272
Re: Air/fuel Ratio Sensor Wed, 31 August 2005 13:40 Go to previous messageGo to next message
ah k, seems like a bit of effort to get all that wired, what is the benifit over a single wire sensor?
Jason
midnight
Re: Air/fuel Ratio Sensor Wed, 31 August 2005 15:24 Go to previous messageGo to next message
it doesnt take as long for the sensor to warm up..
[Updated on: Wed, 31 August 2005 15:24]
Re: Air/fuel Ratio Sensor Wed, 31 August 2005 15:36 Go to previous messageGo to next message
ta2272 wrote on Wed, 31 August 2005 23:40
Jason
sensor heats up in about 30 seconds or so, doesn't cool down during idle, is always up to temperature.... stays cleaner perhaps?
ta2272
Re: Air/fuel Ratio Sensor Thu, 01 September 2005 01:15 Go to previous messageGo to next message
ok i still dont understand what benifit there is for have a 3-4 wire sensore over a single wire sensor????
(or is the only benifit that the sensor gets warm alot faster?)
[Updated on: Thu, 01 September 2005 01:16]
Re: Air/fuel Ratio Sensor Thu, 01 September 2005 01:21 Go to previous messageGo to next message
The sensor has to be at a particular temperature to work properly, the heated one stays at this temperature, the single wire one relies on exhaust temp, so it's temp, and thus accuracy varies.
ta2272
Re: Air/fuel Ratio Sensor Thu, 01 September 2005 03:40 Go to previous messageGo to next message
so the difference between the 3-4 wire units is on the 3 it uses the 1 earth comapared to the 2 earths???\
Jason
also is it a bad idea to use a second hand one of these from the wrecker's?
sideshow
Re: Air/fuel Ratio Sensor Thu, 01 September 2005 03:43 Go to previous messageGo to next message
why do u need the o2 sensor connected anyway
it will just be innacurate most probably
and u cant use it for tuning
most cheap air fuel ratio meters a fukt anyway they either show very righ or very lean
i would never use anyhting like that cause they are innacurate
and a big wank
Re: Air/fuel Ratio Sensor Thu, 01 September 2005 03:52 Go to previous messageGo to next message
ta2272 wrote on Thu, 01 September 2005 13:40
Jason
SIGNAL EARTH
HEATER EARTH
the 3 and 4 wires have a HEATER
the heater ALWAYS has an earth, since it runs 5 amps.
using second hand one is always a bad idea. new ones can be had for $50-60 from ebay.
and it is good to have an O2 sensor for adjusting cruise mixtures.. as long as the ecu is decent enough to actually use one Razz
[Updated on: Thu, 01 September 2005 05:01]
ta2272
Re: Air/fuel Ratio Sensor Thu, 01 September 2005 04:46 Go to previous messageGo to next message
yes sorry for being so stupid, thought i did ask one question, which is in my post above
the one earth earths
SIGNAL EARTH
HEATER EARTH
thanks for your patience
Re: Air/fuel Ratio Sensor Thu, 01 September 2005 04:58 Go to previous messageGo to next message
sorry Wink
3 wire has the SIGNAL EARTH going thru the body of the sensor, then thru the exhaust, then block, then earth strap then body, then ECU earth...
4 wire has SIGNAL EARTH going to ECU earth
the latter is better Very Happy
ta2272
Re: Air/fuel Ratio Sensor Thu, 01 September 2005 05:23 Go to previous messageGo to next message
well i will order a 3 wire one as i know that i can deff wire it up to the wolf 3d v3 as i am unsure if it is possible with the 4 wire one
mic*
July 2005
Re: Air/fuel Ratio Sensor Thu, 01 September 2005 06:00 Go to previous messageGo to next message
The cleaner your ECU earth is to the ECU the better, hence you being told 4 wires better than 3. You are running signal from the sensor to the ECU anyway. Why so hard to run an extra wire with it and have a direct sensor earth to the ECU? The Wolf unit must have an earth somewhere...
Get the four wire sensor.
kingmick
Banned by his request
moved to tamworth
Re: Air/fuel Ratio Sensor Thu, 01 September 2005 06:20 Go to previous messageGo to next message
sideshow wrote on Thu, 01 September 2005 13:43
and a big wank
exactly!100% correct.
mick
ta2272
Re: Air/fuel Ratio Sensor Thu, 01 September 2005 06:38 Go to previous messageGo to next message
well they ony had 3 wire ones in stock at moy exhaust shop so i grabbed one of those, were abouts does it need to be mounted??
NickZ
Launceston
Re: Air/fuel Ratio Sensor Thu, 01 September 2005 12:24 Go to previous messageGo to next message
mount it as close to the motor where it can read all the pipes, exhaust manifold, extractors or turbo dump pipe.
It needs to get as hot as possible to be most acurate.
As for the guys that added its not worth doing, correct me if im wrong, but the later model wolf runs closed loop for crusing mode, isnt it worth using for that.
Im guessing that was the original question as it started with "I am getting a wolf 3d v3 computer and was wondering"?
[Updated on: Thu, 01 September 2005 12:46]
ta2272
Re: Air/fuel Ratio Sensor Thu, 01 September 2005 13:21 Go to previous messageGo to next message
what if it is one of the heated type sensor does it still have to be up close in the system?
NickZ
Launceston
Re: Air/fuel Ratio Sensor Thu, 01 September 2005 22:31 Go to previous message
the the closer to the engine the hotter it will get the more accurate it will be.
Previous Topic:4AGE Convert question
Next Topic:18RG fuel line concerns
Current Time: Sat Nov 21 03:19:10 UTC 2026
Total time taken to generate the page: 0.038317918777466 seconds
