Toymods » Tech & Conversions » Diff Seal leaking.
barbel
Diff Seal leaking. Fri, 27 December 2002 03:32 Go to next message
ok,
have had all the bearings replaced in my diff(ae86) and while i was doin that i changed the seal on it too.
now it leaks out of it. and it didnt happen before i rebuilt it. freakin pissin me off since i have changeedd the seal twice.
is there any tricks to puttin the seal in and should i go get a genuine toyota item rather than a local shop's stock.
cheers,
paul
Bugman
Re: Diff Seal leaking. Fri, 27 December 2002 03:48 Go to previous messageGo to next message
did you use some seal goop aswell?
barbel
Re: Diff Seal leaking. Fri, 27 December 2002 04:06 Go to previous messageGo to next message
yeah, where i could i did...
SUPRAGTE
North Sydney
Re: Diff Seal leaking. Fri, 27 December 2002 07:08 Go to previous messageGo to next message
If its the front seal sounds like you either didn't replace the crushable spacer when you did the bearings if it has one or you have over tightened it.
Is it noisier?
barbel
Re: Diff Seal leaking. Fri, 27 December 2002 09:02 Go to previous message
yeah, i did do it up pretty tight... but it's not noisy now, i replaced everything i could. and the seal do have a crushable spacer i think, if im thinkin of the right thing.
Previous Topic:AC Probs
Next Topic: 1jzgte and 2jzge, Q's
Current Time: Fri Oct 23 04:53:53 UTC 2026
Total time taken to generate the page: 0.15482497215271 seconds
