Toymods » Tech & Conversions » 2J cam gears
joorsh
2J cam gears Wed, 31 August 2005 13:23 Go to next message
Just curious if anyone here has adjustable cam gears on a 2JZGTE, and if so what settings do you run and with what results over standard timing?
I'm told spazzing 2 deg on the inlet and advancing 4 on the exhaust is the way to go. Yes... no... maybe... ?
Re: 2J cam gears Wed, 31 August 2005 23:31 Go to previous messageGo to next message
Don't dick with the cam timing unless you have programmable engine management, and the time/motivation to experiment with different settings on a dyno. Frankly I wouldn't bother. Smile
Oh, and if you get adjustable gears, don't get the HKS ones! JUN gears are apparently good though.
Chris Davey
sunny coast, qld
Re: 2J cam gears Thu, 01 September 2005 00:41 Go to previous messageGo to next message
I always thought that cam gears can't really do that much except move the power band around. If you still have the same duration cam 233deg or whatever it is, then all you can do is make air go in or out of the engine a couple of degrees early or later. But in the end you still only have 233 deg cams. For the price of cam gears, I wouldn't bother. But some longer duration cams that don't have too much lift so you won't need new valve springs and retainers and then have much greater time with valves open. That is what I plan to do anyway Smile
joorsh
Re: 2J cam gears Thu, 01 September 2005 00:45 Go to previous messageGo to next message
I heard the HKS ones wear on the teeth - is this the only reason to avoid them?
As for dyno-time/motovation to mess with the settings, that shouldn't be a problem either.
Chris Davey
sunny coast, qld
Re: 2J cam gears Thu, 01 September 2005 01:00 Go to previous messageGo to next message
You can't change the inlet one can you because of the cam timing sensors?
[Updated on: Thu, 01 September 2005 01:01]
1JZ.747
Osama's hideout
Re: 2J cam gears Thu, 01 September 2005 01:59 Go to previous messageGo to next message
4 horsepower its worth, seen my tuner root around with another customers soarer for an hour, 4 horsepower. pretty pointless with standard cams
BlackSupra
Re: 2J cam gears Thu, 01 September 2005 08:56 Go to previous messageGo to next message
i laugh at you josh.
Told you cams were better investment.
joorsh
Re: 2J cam gears Thu, 01 September 2005 10:13 Go to previous messageGo to next message
I dunno dongah.
I watched a dyno tune on a 2J still with standard ecu, and they managed +8 rwkw and were still going when I left, just from a set of HKS cam gears. MK4.com also seem to think that 10kw from cam gears is not unreasonable.
2 x cam gears = $350
+ 10 kw
= $35 per kw
vs
2 x camshafts = $1250
then you need a new ECU
1 x mid-range ECU = $1500
1 x ecu tuning = $500
= $3250 total
Now lets say you manage to get an extra 50kw
= $65 per kw
You would need to make nearly 100kw extra from cams and ecu on a stock motor for it to be a "better investment".
joorsh
Re: 2J cam gears Thu, 01 September 2005 10:14 Go to previous messageGo to next message
Add to that the fact that I DON'T WANT 300 rwkw. I'm quite happy with 250, and I'm quite happy with the fuel economy that I get from a standard ecu with standard cams.
Manny
Re: 2J cam gears Thu, 01 September 2005 11:31 Go to previous messageGo to next message
Retarding the exhaust cam gear 3 or 4 degress on stock ECU/stock cams is effective on a 1JZ-GTE - I gained 3-5rwkw through the midrange and pulled the power/torque curves across due to earlier spool.
Results will always depend on other mods but anything from 3-30rwkw is possible.
This was a recent post run-in mild tune at 15psi when we tested different camgear settings on my new 1.5JZ engine - final settings as graphed below were exhaust 4 degrees retarded and intake 2 degrees advanced on HKS 264/264 cams.
http://www.trackdaymedia.com/~manny/Tech%20&%20Diag/Dyno%20camgear%20comoarison.jpg
I had issues with my original HKS adjustable cam gears wearing down to the point where they snapped my < 10,000km old cambelt after 60,000 odd km of camgear use.
I switched to JUN ajustable camgears which use the OEM Toyota outer section with a new billet centre section. I also had UAS copy the JUN design and they now offer exchange adjustable camgears for 1J/2Js.
[Updated on: Wed, 07 September 2005 14:36]
Manny
Re: 2J cam gears Wed, 07 September 2005 15:03 Go to previous messageGo to next message
OK, for everyone that contacted me and asked, here are pics and infp on the UAS JUN Replica camgears
Front
http://www.trackdaymedia.com/~manny/Tech%20&%20Diag/UAS/Front.JPG
Back
http://www.trackdaymedia.com/~manny/Tech%20&%20Diag/UAS/Back.JPG
Material/Design Specifics-
JUN replica adjustable camgears
utilise oem outer hardened contact teeth for reliability
Suit Toyota 1JZ / 2JZ engines
CNC machined billet alloy centres
Stainless steel M6 button head Allen key cap bolts
Twin 0.7mm high tensile washers for strength and self locking
Adjustable +/-8 degrees with reference marks
Normal RRP $185 exchange + $45 deposit each
special release price $130 exchange + $45 deposit each
Note that John has a limited pool of 5 exchange camgears, so it's a case of first in, first served and if the exchange camgears aren't returned promptly, then the next user is affected.
For queries, availability and ordering, e-mail John Penlington at sales@uniqueautosports.com
Mods, I'm only passing on this info for the benefit of members, but if this post breaches any commercial posting guidelines, feel free to contact me and edit as necessary.
[Updated on: Wed, 07 September 2005 15:06]
ed_ma61
Lost in the K hole
Re: 2J cam gears Thu, 08 September 2005 01:43 Go to previous messageGo to next message
so is that $130 for a pair or EACH ??
ill be sending an email soon
ed
Re: 2J cam gears Thu, 08 September 2005 01:49 Go to previous messageGo to next message
each from what I can see, hence me not being too interested. And is that $130 + $45 deposit = $175 each?
ed: flywheels!
ed_ma61
Lost in the K hole
Re: 2J cam gears Thu, 08 September 2005 01:52 Go to previous messageGo to next message
130ea is a bit crazy. thats about $20 worth of alloy, and maybe 1hr machine work Rolling Eyes
$130 pair is a good price exchange
$185 pair is what id call reasonable exchange
ed_ma61
Lost in the K hole
Re: 2J cam gears Thu, 08 September 2005 03:05 Go to previous messageGo to next message
Each
$130 exchange with $45 deposit.plus $15 freight
Regards,
John Penlington
Unique Autosports
Japanese Import Specialists
www.nismo.com.au
Phone: 02 9634 8000
Fax: 02 9634 8888
Re: 2J cam gears Thu, 08 September 2005 04:53 Go to previous messageGo to next message
well... that makes for a shitty deal, even if you live in sydney and pick up.
Manny
Re: 2J cam gears Thu, 08 September 2005 07:50 Go to previous message
Dunno, if you're the small percentage on here who can make these yourselves or have a mate that can make them, then sure you can get them cheaper, but for the vast majority of us who don't have those contacts or resources, buying them is the only option.
Now if you're happy to pay $300 each for a brand name, sure go for it as I had to in the past, but if you want something in between that is reliable and well made, then this is an option.
Note that I've been reading on here for a few years about how easy and cheap it is to make these, yet I'm yet to find any info about them actually being made and made available to the public.
I asked John to make these for the 1JZGTE Soarer guys who have swamped him with interest and orders but also thought some on here may benefit - my apologies if I just wasted bandwidth.
John is offering these at cost in the hope that he will occasionally be paid to fit the odd set and tune the odd set on his dyno.
In the meantime if it's supply only on exchange, he's only helping the engineer who jigged up, made the centres and batch machines the outers pay for his overheads and pay for his time and in turn put food on his family's table - great if he just wants to support the local engineering industry instead of sending the work to China, but of little personal financial benefit.
Either way, if my post is of no general use to the masses, feel free to nuke it.
[Updated on: Thu, 08 September 2005 07:52]
Previous Topic:ae86 suspension help
Next Topic:LPG on MX83
Current Time: Fri Nov 20 14:11:09 UTC 2026
Total time taken to generate the page: 0.0079879760742188 seconds
