Toymods » Tech & Conversions » Roll Center Adjuster?
pepsicola
Roll Center Adjuster? Fri, 27 December 2002 03:55 Go to next message
ppl say if the car is lowered, the roll center will change.
then we'll need a roll center adjuster.
I want to know what will be affeted with the roll center changed?and how?
Thanks.
pepsicola
Re: Roll Center Adjuster? Fri, 27 December 2002 08:34 Go to previous messageGo to next message
bump
Ribbo
Northern Beaches
Re: Roll Center Adjuster? Fri, 27 December 2002 09:23 Go to previous messageGo to next message
search on it
mtsbirch
Edmonton, Alberta, Canada
Re: Roll Center Adjuster? Sat, 28 December 2002 06:37 Go to previous messageGo to next message
Unfortunately there is no such thing as a roll center adjuster. Roll center is only one factor of overall suspension geometry. It affects body roll and how the suspension responds to body roll. Lowering a car changes the roll center in the same way that it changes camber and, in some vehicles, caster. Ideally, roll center should not change throughout the travel of the suspension. If it does, the car will feel like the handling is changing every time the suspension compresses or extends.
One major factor affecting roll center is the control arm length, which is engineered for factory ride height and can get way out of whack if a car is lowered too much.
I would recommend the book "Chassis Engineering" by Herb Adams for a thorough explanation.
I've heard that lowering a car 1-2 inches shouldn't affect too much but do a little checking for your car specifically as suspension geometry varies between models and manufacturers.
Jayem
Finland
Re: Roll Center Adjuster? Sat, 28 December 2002 15:31 Go to previous messageGo to next message
Fortunately there is such a thing as roll center adjuster. It's basically simple block that comes between lower control arm and strut to fix suspension geometry due to car lowering job. In other words, it places lower control arms closer to original position.
http://www.twelve100.com/images/Battle%20Version%20Calatog/DSC00745.jpg
mtsbirch
Re: Roll Center Adjuster? Sat, 28 December 2002 17:59 Go to previous messageGo to next message
I stand corrected. Smile
ddeane
PNG
Re: Roll Center Adjuster? Sun, 29 December 2002 08:24 Go to previous messageGo to next message
Whiteline $185
Hunty
Re: Roll Center Adjuster? Sun, 29 December 2002 13:45 Go to previous message
ahh whiteline....is there anything they can't do
Previous Topic:Spray painting advice
Next Topic:4ac head on a 7afe block??
Current Time: Thu Nov 19 10:02:59 UTC 2026
Total time taken to generate the page: 0.0060629844665527 seconds
