Toymods » Tech & Conversions » Tacho Signal Converters "1JZ Conversion working"
Driften ZZE123
Tacho Signal Converters "1JZ Conversion working" Wed, 31 August 2005 23:32 Go to next message
Hey guys
I finally got my 1JZGTE conversion to run. Oh yeah I was wondering here who ever has done this type of coversion what kit did you need to get inorder to get the 1JZGTE ecu output to work for the tacho on the MA70 dash? Any help will be much appreciated
Will
Re: Tacho Signal Converters "1JZ Conversion working" Wed, 31 August 2005 23:46 Go to previous messageGo to next message
I wasn't aware that the MA70 needed a booster/converter for it to work, you should just be able to hook up your tacho output on the ECU to the tacho wire for the dash.
Henn
Rosanna, Melb
Not 100% sure, but this thread may be some help.
A bit past the pisstaking first few posts.
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 00:15 Go to previous messageGo to next message
You can either source a JZA70 dash or use one of Grant's tacho boosters.
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 00:22 Go to previous messageGo to next message
Norbie wrote on Thu, 01 September 2005 08:15
Does it require a booster though? I thought the Mk3's already ran off the 5V signal like the 1JZ tacho pin puts out? My 1GGTE from a Mk3 did, and I thought 7M's did too.
sideshow
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 01:45 Go to previous messageGo to next message
i sell tacho boosters that work with 80% of toyotas and aftermarket ecus
i have alot of the ones that i use for a 1j conversion
pm me for a price
dingaling
tas
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 06:01 Go to previous messageGo to next message
Grant, spose you didn't get my e-mail, but anyway this looks like the appropriate time to ask you.
recently swapped a 86kw 4age (aw11 mr2) with a fwd beams 3sge blacktop (from a caldina)
and the tacho in the mr2 is acting eradic. It fluctuates up and down around the 2000rpm mark.
Does this sound like an easy fix with your tacho booster?
[Updated on: Thu, 01 September 2005 13:24]
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 10:48 Go to previous messageGo to next message
What's wrong with the tacho wire on the igniter? It's one of the wires on the smaller plug, can't remember the colour from the top of my noggin.
dingaling
tas
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 10:53 Go to previous messageGo to next message
Eh erm, more info needed can't make a clear mental picture.
Smaller plug? beams engine may have a diff setup Confused
HyDrA
Adelaide, SA
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 13:19 Go to previous messageGo to next message
I always got the impression that the tacho wire is black. It has been in most cases that i've seen... black, or yellow!!
Wait, toyota wiring never tells the truth Wink
clubagreenie
1st street on the right
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 13:20 Go to previous messageGo to next message
You've clearly never worked on a British car...
HyDrA
Adelaide, SA
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 14:06 Go to previous messageGo to next message
Oh, I know they are a wiring nightmare!
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 14:35 Go to previous messageGo to next message
Does anyone want to admit to ever working not only on a Pom car, but anything European?
sideshow
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 23:00 Go to previous messageGo to next message
ive done both a 7mgte and a 1jz into an ma70
and both times ive had to use a tacho booster
the ones i use for a 1j into a cressida should work on a ma70
just trace the ig- wire from the diag box to inside the car
dingaling
tas
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 23:32 Go to previous messageGo to next message
Ok so i may need one of these tacho boosters to get the beams 3sge tacho signal to work on a 4age mr2 dash.
Except i'm not sure if the erratic jumping up and down of the tacho indicates that is the problem. Or if it's got another signal going to it alltogether (one that is an up and down voltage that doesn't appear to relate to speed of engine)
And Ah crap! the diag box wasn't wired into this loom! (seller made the loom)
[Updated on: Thu, 01 September 2005 23:33]
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 23:45 Go to previous messageGo to next message
Driften ZZE123, was the car originally a 7MGE or a 7MGTE?
sideshow
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 23:48 Go to previous messageGo to next message
if the engine has a single coil
just get the tacho wire and wire up to the neg side of the coil
this is the strongest signal u can find on the engine for the tacho
if the tacho still jumps around there might be other probs
tacho boosters are usually needed for when goin from a single coil to multiple coils and the signal from 1 coil is not accurate so u have to run it from igniter which has weak signal
Re: Tacho Signal Converters "1JZ Conversion working" Thu, 01 September 2005 23:59 Go to previous messageGo to next message
sideshow wrote on Fri, 02 September 2005 07:48
Or you are trying to run a 1GGTE which although having 1 coil has a f'ed up setup to match the 7MGTE.
dingaling
tas
Re: Tacho Signal Converters "1JZ Conversion working" Fri, 02 September 2005 03:32 Go to previous messageGo to next message
Thanx Sideshow, yes it used to be single coil, now to an engine with a coil on each spark plug. But the wiring loom that was already made up must already be getting a signal form the ECU, a weak one by the sounds of it.
sideshow
Re: Tacho Signal Converters "1JZ Conversion working" Fri, 02 September 2005 06:50 Go to previous message
well if u put the tacho wire onto just one coil it will read 1/4 the rpm but this will atleast tell u if the signal is weak
or tacho is fukt
if tacho works fine but reads 1/4 revs then the signal might be too weak
i have 3 diff models of tacho boosters they all range in price
i also have autronic tacho boosters
these will take 4 signal sin one add em up and have one output
so therefore u can run each of the 4 inputs from 4 coils
then it will have one 4cyl output
but these are not cheap
but i find most toyotas like one model of booster
vls and rbs like another model
and so on
anyway tacho boosters and tip tronic devices are gettin hard to buy these days as the supliers find it hard to get parts and time
so im looking for new suppliers every day
im goin to the usa in a month to find new customers and suppliers as gettin stuff made in australia is a pain in the ass sometimes
or u can just make the parts yrself
[Updated on: Fri, 02 September 2005 06:53]
Previous Topic:GX81 coilover
Next Topic:1G-GZE boost upgrade
Current Time: Fri Oct 23 18:34:38 UTC 2026
Total time taken to generate the page: 0.0079669952392578 seconds
