Toymods » Tech & Conversions » Changing diff ratio's
joorsh
Changing diff ratio's Thu, 01 September 2005 04:35 Go to next message
I'm wanting to change the diff ratio in my MA61, because at the moment 1st gear is utterly useless, and freeway driving is a little unpleasant in 5th gear at over 3000 rpm.
I've done a bit of snooping and searching, and from what I gather I currently have 3.9 ratio, and I'd probably be best off going for something around the 3.5 ratio mark. Thanks to a few very helpful posts by toymodders, I've identified the diff code I need as being "F372".
This is out of the RA65 correct?
Is there any difference between the auto/manual?
Did any other cars come with this diff?
Can I just rip the crown/pinion out of the RA65 diff, and chuck it in my MA61 diff? No fiddling or fabricating - direct bolt in?
Thanks again fellas.
[Updated on: Thu, 01 September 2005 04:50]
Re: Changing diff ratio's Thu, 01 September 2005 05:32 Go to previous messageGo to next message
It comes out of an RA65, manual only. You might find it in a manual RT142 Corona as well, not sure though.
Yes it's a direct fit, but I strnogly recommend you get a diff shop to do it.
This is exactly what I did in my car a couple of years ago. You seem determined to learn stuff the hard way - why don't you just ask first? Laughing
joorsh
Re: Changing diff ratio's Thu, 01 September 2005 07:11 Go to previous messageGo to next message
I thought I was asking! Very Happy
I don't like to just ask a question without at least putting in a bit of research first. Besides, I always find you learn stuff better if you figure it out for yourself. That way when a problem comes up that hasn't been dealt with before, you're better equipped to figure the sucker out Smile
Chris Davey
sunny coast, qld
Re: Changing diff ratio's Thu, 01 September 2005 07:26 Go to previous messageGo to next message
Norbie: why do you say to get a diff shop to do it? I don't know if it is harder in an IRS car but I thought it was pretty easy. Pull wheels off, pull brakes off, pull axles out, pull tailshaft off, undo diff bolts after draining fluid! and bob's your uncle. Smile
Re: Changing diff ratio's Thu, 01 September 2005 07:27 Go to previous messageGo to next message
He's not just talking about swapping the whole diff, he's talking about fitting a different crown-wheel and all to the LSD centre.
joorsh
Re: Changing diff ratio's Thu, 01 September 2005 07:30 Go to previous messageGo to next message
Indeed. I have a few bits and bobs to put together actually - hopefully my trutrac centre will be arriving soon!
Truetrac's kick ass Razz
joorsh
Re: Changing diff ratio's Thu, 01 September 2005 23:29 Go to previous messageGo to next message
Now THAT's what I wanted to hear Very Happy
Re: Changing diff ratio's Fri, 02 September 2005 00:18 Go to previous messageGo to next message
TrueTrac + 3.5:1 ratio = teh win in a turbo MA61. I'm extremely happy with my setup.
Re: Changing diff ratio's Fri, 02 September 2005 00:19 Go to previous messageGo to next message
Norbie wrote on Fri, 02 September 2005 08:18
With a 2JZ maybe Razz
TrueTrac + 3.9:1 ratio = teh win in a 1GGTE GA61 Wink
joorsh
Re: Changing diff ratio's Fri, 02 September 2005 05:48 Go to previous messageGo to next message
Again... exactly what I wanted to hear Smile
Just picked up my manual RA65 diff about 45 mins ago. A little old and clunky, as to be expected, but should do the job. All the teeth on the crown gear felt like they were there. Was just a bit sticky to start turning, and a little sloppy in the play between left/right sides. It's been sitting on a shelf for the better part of 5 years, so it's not really surprising. The wrecker had no idea what it was Smile
Re: Changing diff ratio's Fri, 02 September 2005 07:01 Go to previous messageGo to next message
To give you yet ANOTHER thing you wanted to hear, mine wasn't perfect, but with the careful attention given to it by my mechanic when he assembled the Truetrac into the centre, the whole thing is as tight as a nuns... Wink
Re: Changing diff ratio's Fri, 02 September 2005 07:24 Go to previous message
justcallmefrank wrote on Fri, 02 September 2005 08:19
TrueTrac + 3.73:1 ratio = teh win in a 1UZFE ... car.. Wink
EDIT: I hope...
[Updated on: Fri, 02 September 2005 07:25]
Previous Topic:3S-FE -> 5S-FE...?
Next Topic:GX81 coilover
Current Time: Thu Oct 22 22:52:39 UTC 2026
Total time taken to generate the page: 0.0053589344024658 seconds
