Toymods » Tech & Conversions » Anyone supercharged a 3S-GE?
jambo
Gold Coast, Australia
Anyone supercharged a 3S-GE? Fri, 27 December 2002 06:39 Go to next message
Hello
I'm after an SW20 MR2 and I'd rather not go for a turbo/grey import. I remember hearing about a company that advertised on the net a supercharger kit for the 3S-GE using a second hand jap supercharger from a 1GGZE and sold it as a complete kit with all brackets, etc.
Does anybody else know about these kits or have something similar installed? I would much prefer to go the roots type supercharger than turbo because I am a big fan of bottom end grunt.
PS. Sorry if this has come up before, I can't find anything similar with the search tool.
Re: Anyone supercharged a 3S-GE? Fri, 27 December 2002 06:50 Go to previous messageGo to next message
There are supercharger kits available for 3SGE's in celica's, and kits available for everything from Excel's to Civic's, so even if you can't find a kit, there's no reason it can't be done Very Happy
Phrozen_Death
Tamworth
Re: Anyone supercharged a 3S-GE? Sat, 28 December 2002 14:59 Go to previous messageGo to next message
well if anyone has info on it i would like to try something different rather than a turbo , so any help would be great
Re: Anyone supercharged a 3S-GE? Mon, 30 December 2002 04:55 Go to previous messageGo to next message
if it's low end grunt you're after, a good quality small turbo will get you good power early. if you're after something unique, then that's a different matter. I'm totally biased toward turbos, especially on small capacity engines. too many losses on a supercharger, unless it's a simple bolt on (like 4a-ge - gze)
jambo
Re: Anyone supercharged a 3S-GE? Mon, 30 December 2002 05:23 Go to previous messageGo to next message
Thanks for the replies.
Mrshin: Do you have a link for the place that does the kits for 3S-GE Celicas?
I'd rather go for a proven method that has been done before, but with what I want to achieve I may have to try something new. In a nutshell I am after good usable power down low, minimal maintenance, something that doesn't run too hot (I live in Qld), prefer no turbo timer, and an Australian delivered MR2. The kits with the 1GGZE supercharger (SC14?) were around $2k and supposedly made 130rwkw as is or 160rwkw with a series 4/5 RX7 cooler. But low down grunt should be much more noticable than a turbo model with equivelant power.
This was supposedly a simple bolt on, but I'm hoping somebody else here knows about the kits or can comment on it's feasability.
I wonder how the stock internals would fair up. Companies like CAPA build up their kits with just bolt-ons so it looks promising. I'm going to visit one place this afternoon who say they can adapt the jap chargers to just about anything.
Cheers.
[Updated on: Mon, 30 December 2002 05:25]
Phrozen_Death
Tamworth
Re: Anyone supercharged a 3S-GE? Mon, 06 January 2003 04:59 Go to previous messageGo to next message
i would be very interested to hear how you went jambo
RWDboy
Re: Anyone supercharged a 3S-GE? Mon, 06 January 2003 07:28 Go to previous messageGo to next message
Stock internals will do alright to a point (duh). And the Aussie 3S-GEs are about as potent as a limp weiner, they only run about 9:1 compression (maybe more for 2nd gen in SW20)
Superchargers don't produce nearly the same amount of heat as a turbocharger, but they also don't produce the same amount of boost, which means that they are more reliable, but perhaps not quie as exciting as a turbo.
Also note that there are turbo kits out there that don't require internal modification.
You can grab a copper head gasket from ridgecrest and get it made to about 2mm thickness which will decrease the compression ratio a small amount, and also won't blow under the extra pressure in the combustion chamber supplied by the supercharger, this is probably the only "modification" that you'd need.
I reckon you could probably get about 8-10psi boost if you engineered everything well enough and it would run very reliably.
As for the kit, I have no idea Smile
[Updated on: Mon, 06 January 2003 07:29]
Re: Anyone supercharged a 3S-GE? Mon, 06 January 2003 07:32 Go to previous messageGo to next message
Superchargers create just as much heat as turbochargers at any given boost level. The laws of thermodynamics apply here; compress any gas and it will get hot! Some types of superchargers (eg roots) actually generate more heat than turbos due to their inferior adiabatic efficiency.
RWDboy
Re: Anyone supercharged a 3S-GE? Mon, 06 January 2003 07:39 Go to previous messageGo to next message
The combustion gases may heat up as much, but the under bonnet temperatures are way lower (sorry I forgot about that), I thought that the turbocharger itself got way hotter than a supercharger ever would.
Also the back pressure in the exhaust from a turbo heats up the exhaust manifold too, or so I thought, sorry if I'm wrong, I wouldn't intentionally mislead anyone!
jambo
Re: Anyone supercharged a 3S-GE? Mon, 06 January 2003 08:07 Go to previous messageGo to next message
Thanks for the input fellas.
This company quoted me $4500 for the full kit running only 4-5psi non-intercooled. He said add another $1500ish for RX7 s4/5 cooler, plumbing and more boost..... yikes. That's without even touching the ecu, he reckons any more than about 5psi and it would be ecu changeover time as well. That's a bit of a step up from the $2000 I heard last time. But the had a Lola Le Mans car in the shop which was some form of consolation.
I've been chatting to a guy who's develping his own kit for a 5S-FE yank spec model so I might see what's involved in doing it myself. If all else fails I guess I'll have to go for one of the turbo models or maybe a 180/200sx.
Cheers.
Re: Anyone supercharged a 3S-GE? Mon, 06 January 2003 08:39 Go to previous messageGo to next message
you're both right
depending on boost, they will both heat to the same level due to that
BUT
with a turbo you've also got your exhaust passing through the same unit, heating it up even more.
the trade off with a supercharger is (generally) less power as it is driven by the engine, so reqires some engine power to work, whereas a turbo is using the waste (exhaust) to acheive boost
Re: Anyone supercharged a 3S-GE? Mon, 06 January 2003 08:44 Go to previous messageGo to next message
$1500 for an intercooler is bs, especially since you'd be getting a 2nd hand one.
you could pick up a mk3 supra intercooler nice and cheap and use that (if you're keen)
and of course, when you're only running 5 pounds of boost an intercooler isn't going to make that much of a difference.
RWDboy
Re: Anyone supercharged a 3S-GE? Mon, 06 January 2003 09:10 Go to previous messageGo to next message
I think one problem is you can't piggy back ECUs on a 3S-GE (as far as I know), but I reckon a little over 5 psi boost could be handled by the standard ECU easy, you might just not be getting as much power as if you changed it. I don't konw how much spark you'd get either, most likely you'd have to reduce the spark plug gap to make up for it, but that's a piece of pie.
And $1500 for an intercooler is definitely garbage. Although I have to ask (out of curiosity) where's a good spot to put an intercooler in an MR2?
Still sounds a tad expensive just for the base $4500, probably not worth it unless you value "being different" a helluva lot.
Re: Anyone supercharged a 3S-GE? Mon, 06 January 2003 12:41 Go to previous messageGo to next message
3 options in an mr2.
you can have guard mounted, you can have "top" mounted (which most times are closer to side mounted, and often have a snorkel on the roof to get the air flowing onto it) and I've also seen a front mount.
admittedly the front mount was on a drag MR2, so the massive amounts of turbo lag didn't matter
jambo
Re: Anyone supercharged a 3S-GE? Tue, 07 January 2003 01:38 Go to previous messageGo to next message
Yeah I've seen a ludicrous front mount setup with piping running through the cabin!
I'm not keen on this joint's prices. I mean I'm no expert but in all seriousness, what has to be done that is worth $4500 without ecu? The SC14 is only $3-400, I'm sure I could get a metal fabrication place to make up a simple bracket or do it myself. Piping's another issue but surely not worth much more than $500? I'd assume I could run it in line with the aircon (longer belt obviously), I'd also like to source a check valve so I can use the inbuilt clutch to engange and disengage the s/c from inside the cabin, Mad Max style. Anyone know where I can find one? It would be great for fuel economy, rainy days, etc.
The guy in the US has fabricated his brackets but the s/c will be protruding through the engine lid by about an inch, so he is making up a little fiberglass bubble to cover it.
As far as cooler goes, I have seen MKIII supra ones for $100-150 and a MKIV one for $150. They do recommend the rx7 cooler for some reason, but I can't see it costing any more than that. Piping and mounting, I have no idea how much this would cost to make up, $500-700? I'm not after anything showy. Does anyone have a ballpark figure, say if somebody has supercharged a 4A-GE for example?
Then ecu, well, that sux if you can't piggy back onto the stock one. I'll have to do some more research on this.
Can anybody suggest something with injectors/fuel rail? I'm sure I could pick up some higher rated second hand ones from a different engine.
I've found two guys in Sweden with supercharged 3S-GEs in their MR2s using the Ludi Motorsports kit which is even more expensive than the Blitz kit ($US6000). Both cars are making 240hp (I assume that's at the crank but haven't confirmed yet). They are going to email me some pics which will give a good idea of placement and mounting brackets. I'll post them up here.
Don't get me wrong, I would love to have the same thing as everybody else (I'm driving a Falcon GLi atm for crying out loud). I am not out to get attention or be a pioneer.... I just really cannot stand turbo lag or the hassles of owning a grey import.
Cheers.
[Updated on: Tue, 07 January 2003 01:44]
Re: Anyone supercharged a 3S-GE? Tue, 07 January 2003 04:17 Go to previous messageGo to next message
my god
US$6000 ?!?!
for that you could drop in a 3s-gte, put a better turbo on it, good fmic (or guard mount in your case.. the mkIV might me a good idea, they're very good apparently), wind the boost up, cool air intake, and have money left over.. and be making well over 240 at the crank
jambo
Re: Anyone supercharged a 3S-GE? Mon, 20 January 2003 04:14 Go to previous messageGo to next message
For anyone who's interested, here are some pics and movies of a couple of Supercharged 3SGE MR2s in Europe
http://homepage.hispeed.ch/rolandtb303/Supercharge d15-12/index.html
wilbo666
Re: Anyone supercharged a 3S-GE? Mon, 20 January 2003 05:57 Go to previous message
What are the hassles of a grey import? Seeing as we have SW20's over here what parts aren't interchangeable? And if you go and SC one wont your insurance be effected much to the same as an import? Maybe there is something I'm missing?
Previous Topic:1G-GTE oil filter
Next Topic:Piston Selection Help Needed
Current Time: Fri Nov 20 00:56:42 UTC 2026
Total time taken to generate the page: 0.023864984512329 seconds
