Toymods » Tech & Conversions » car dies, whats wrong, {18rg}
Mr DOHC
car dies, whats wrong, {18rg} Thu, 01 September 2005 08:46 Go to next message
i was cruising along the road today, after i got my exhaust fixed, then all of a sudden, the car dies, i gave it a bit of throttle {didnt realise what was going on yet} and it splutters and the engine shuts off.
if i try to restart it, it starts for a sec and then when i back off the starter, back to ignition that is, it dies.
doesnt matter if i give it more throttle either
racq came out, he couldnt work it out {duh}
i have a new electronic ignition in it too
help me
jeffro RA28
Tamworth
Re: car dies, whats wrong, {18rg} Thu, 01 September 2005 08:51 Go to previous messageGo to next message
If u hold the key on "start" does it stay started and then die when u let it go again?
If so check ur balast resistor and then if that doesnt work check the ignition wire mechanism at the back of the key barrel, often the spring goes or just wears out.
Bypass the resistor to check it.
[Updated on: Thu, 01 September 2005 08:51]
Mr DOHC
Re: car dies, whats wrong, {18rg} Thu, 01 September 2005 08:53 Go to previous messageGo to next message
the resistor WAS bypassed,
on top of my ignitor, it has "7.6"
thats not voltage is it, cause it was probably getting more than that
jeffro RA28
Tamworth
Re: car dies, whats wrong, {18rg} Thu, 01 September 2005 09:24 Go to previous messageGo to next message
iv got no idea at all on electrics. I just knew that was a way to check the resistor. It could also be in the key barrel, i have to replace the particular part 3 times b 4 i found one that worked.
Send me a MSN msg if u want to see some photos of what i am talking about
brett_celicacoupe
townsville NQLD
Re: car dies, whats wrong, {18rg} Thu, 01 September 2005 10:18 Go to previous messageGo to next message
check you didnt blow the "ignition" fuse
also check if the wire has disconnectd from the resistor/igniter
i think for memory the coil is hard wired for power in the start position
TurboRG
Nor Calif USA
Re: car dies, whats wrong, {18rg} Thu, 01 September 2005 18:25 Go to previous messageGo to next message
check your fuel filter.
sounds like your running out of gas.
Mr DOHC
Re: car dies, whats wrong, {18rg} Thu, 01 September 2005 21:00 Go to previous messageGo to next message
i will check all those things in about 1 hour fellas
thanks for the help
Mr DOHC
Re: car dies, whats wrong, {18rg} Thu, 01 September 2005 22:04 Go to previous messageGo to next message
plenty of fuel in the fuel filter {its new} and the "engine" fuse is ok
but my battery is dead, any more ideas
chrishulbert
Castle Hill NSW
Re: car dies, whats wrong, {18rg} Fri, 02 September 2005 03:16 Go to previous messageGo to next message
Mr DOHC wrote on Fri, 02 September 2005 08:04
Charge it/replace it then! 7.5 isn't enough volts.
Mr DOHC
Re: car dies, whats wrong, {18rg} Fri, 02 September 2005 03:19 Go to previous messageGo to next message
the batery is dead cause i kept trying different things to get it going, it had 11.5 when racq got there {after i tried cranking a few times}
the ignitor has 7.6 written on it,
anyway, its at the autoelec now, see what they say
pomey
May 2005
Re: car dies, whats wrong, {18rg} Fri, 02 September 2005 07:47 Go to previous messageGo to next message
Hello,
Could also be the altenator. I had the same thing on my Subaru and my Dad too on his Pajero. I replaced my altenator but dad's was just a loose connection. Scoobydoo works fine now, stil goin after 377,000 kms!
If not, then battery and all other previous suggestions. Or like u have all ready done, employ the proffesionals!
Cheers, Pomey!
Mr DOHC
Re: car dies, whats wrong, {18rg} Fri, 02 September 2005 08:12 Go to previous messageGo to next message
elec system is fine
fuel pumps dead, no fuel getting to carbs
fuck
Re: car dies, whats wrong, {18rg} Sat, 03 September 2005 11:59 Go to previous message
teehee - I DIDNT BREAK IT!! ner ner ner ner!!
Previous Topic:speedo problem
Next Topic:My car doesn't have some electrics(A query for sparkies)
Current Time: Wed Nov 25 14:20:57 UTC 2026
Total time taken to generate the page: 0.12442588806152 seconds
