Toymods » Tech & Conversions » ae92 temp gauge not workin
mjd5
fairfield
April 2005
icon14.gif  ae92 temp gauge not workin Thu, 01 September 2005 11:42 Go to next message
NEED HELP my ae92 temp gauge not workin .. i got smallport motor
i think sensor not workin or not plug in ????
thank
jkvsnn
Re: ae92 temp gauge not workin Fri, 02 September 2005 08:31 Go to previous messageGo to next message
mine's not working either. In my case its the plastic circuit board on the back of the gauges, you can see where it's burnt out. Check that before you buy a new sensor.
Julian.
mjd5
fairfield
April 2005
Re: ae92 temp gauge not workin Fri, 02 September 2005 10:31 Go to previous messageGo to next message
thank manz ... i check the bord today look fine? u knw what sensor i need to replace or check
and where abt is this sensor
jkvsnn
Re: ae92 temp gauge not workin Fri, 02 September 2005 13:09 Go to previous messageGo to next message
depends on what engine you've got I think. Mines a 20VST and the temp sensor is in the thermostat housing.
187_20v
Re: ae92 temp gauge not workin Fri, 02 September 2005 17:22 Go to previous messageGo to next message
ive got the same problem too
well before it was working when i accelerate when driving but when i didnt it would not move and now i think it just dont move even when i do accelerate , my mechanic told me mayb a ground wire fall out and would look at ot 4 me but i never have time to go cause i need the car 2 drive 2 work
gonna pull out the dash tomorrow and see
and i also got a 20vst and where is the thermostat housing located in the engine bay
jkvsnn
Re: ae92 temp gauge not workin Fri, 02 September 2005 21:04 Go to previous messageGo to next message
just below the dizzy
Scorpion
Menai area of Sydney
Re: ae92 temp gauge not workin Sat, 03 September 2005 02:24 Go to previous messageGo to next message
Where the top radiator hose connects to the engine, near where the oil dipstick is. Its a single wire and slides on to the sensor that stcks out horizontally from the aluminium fitting where the hose joins the head.
jkvsnn: thats the oil pressure switch or sensor.
Re: ae92 temp gauge not workin Sun, 04 September 2005 11:17 Go to previous message
Take the wire off the sensor and short it to ground, the gauge should go to full hot. Replace the sensor if this is the case, and see what happens - making sure the body of the sensor is well earthed. If you still have issues, slip out the IC and check for grounding issues, they can make temp gauges do funny things.
Previous Topic:Timing Belt tensioner bearing
Next Topic:4AGE missing when throttle very slightly open.
Current Time: Thu Oct 22 10:51:54 UTC 2026
Total time taken to generate the page: 0.0063431262969971 seconds
