Toymods » Tech & Conversions » how to get the drum off r118corona diff
MCA corona
launceston
August 2005
how to get the drum off r118corona diff Thu, 01 September 2005 12:54 Go to next message
i am stumped how are you spose to get the drums off any photos or just an explenation would be grate
cheers justin
clubagreenie
1st street on the right
Re: how to get the drum off r118corona diff Thu, 01 September 2005 13:19 Go to previous messageGo to next message
My first response is to say
1/ unbolt entire rear end
2/ replace with disc rear end
However since you are trying to remove the drums and this is not a natural first step in performing the above mod lets start again.
Is the handbrake off? I know it's obvious but it's also late and I'm sure I'm not the only one who's been caught by this. Are there any screws in it? Don't know about the corona but some have screws holding the drum to the drive flange. Tap around edges with hammer while levering (preferably in more than one spot) off. But this will take more hands than you have. Adjust the brakes, if the drums are worn enough there may be a lip inside and the shoes are catching on this.
fangsport
timaru NZ
Re: how to get the drum off r118corona diff Mon, 05 September 2005 11:57 Go to previous messageGo to next message
most, if not all Toyotas have 2 M6 or M8 tapped holes in the drum. insert appropriate bolts evenly into each hole and the drum will fall off.
they usually catch due to corrosion around the centre (i.e. axle) hole.
ke30king
On Probation
launceston tas
March 2005
Re: how to get the drum off r118corona diff Mon, 05 September 2005 12:29 Go to previous message
handbrake off bash it with a mallet until its wobley then pull it off
Previous Topic:4AGTE Exhaust size
Next Topic:CA18DET FLYWHEET problems need HELP
Current Time: Mon Nov 9 22:06:58 UTC 2026
Total time taken to generate the page: 0.062055110931396 seconds
