Classifieds » Engines, Accessories and other Mechanicals » 4AGZE 175mm pulley kit
RSSTi
Melb, Victoria
4AGZE 175mm pulley kit Thu, 01 September 2005 22:05 Go to next message
It uses a factory pulley complete with damper and a CNC machined 175mm outer modified by Performance Engineering.
Comes with 2 drive belts and idler pulley.
Picture of kit
Email
$350.
JNR 13B
Re: 4AGZE 175mm pulley kit Fri, 02 September 2005 12:41 Go to previous messageGo to next message
how much boost does it run?
I have friend who might be interested.
cheer
feral4mr2
Bundaberg, Qld.
Re: 4AGZE 175mm pulley kit Sun, 04 September 2005 11:40 Go to previous messageGo to next message
the 175mm pulley gives ~14psi.
RSSTi, do you have a timing pointer with the kit?
DODGY86
Re: 4AGZE 175mm pulley kit Sun, 04 September 2005 14:30 Go to previous messageGo to next message
YOU GOT PM!!!
RSSTi
Melb, Victoria
Re: 4AGZE 175mm pulley kit Sun, 04 September 2005 21:35 Go to previous messageGo to next message
I don't have a timing pointer with it.
hutchiroku
Central Coast
Re: 4AGZE 175mm pulley kit Sun, 04 September 2005 23:51 Go to previous messageGo to next message
excuse my ignorance but what is a timing pointer and why is it needed for this kit to be put on?
RSSTi
Melb, Victoria
Re: 4AGZE 175mm pulley kit Mon, 05 September 2005 00:02 Go to previous messageGo to next message
It's not required to put the kit on but you must remove the factory pointer to fit the kit and some kits come with a re-located pointer.
hutchiroku
Central Coast
Re: 4AGZE 175mm pulley kit Mon, 05 September 2005 05:56 Go to previous messageGo to next message
So how did u relocate your pointer when you had this kit on. Is the pointer still required for coil pack gze's?
RSSTi
Melb, Victoria
Re: 4AGZE 175mm pulley kit Mon, 05 September 2005 06:58 Go to previous messageGo to next message
Pointer is only there for you to set the ignition timing, it points too top dead center when using a timing light and not required run the engine.
RSSTi
Melb, Victoria
Re: 4AGZE 175mm pulley kit Mon, 05 September 2005 21:43 Go to previous message
Pulley sold pending payment.
Previous Topic:FS: Garrett GT2535
Next Topic:FS: W50 w/o shifter
Current Time: Tue Oct 20 11:48:40 UTC 2026
Total time taken to generate the page: 0.0049068927764893 seconds
