Toymods » Tech & Conversions » Sprinter struts + coilover sleeves measurements
xolent
Sprinter struts + coilover sleeves measurements Fri, 02 September 2005 02:33 Go to next message
I don't have a vernier/telescopic gauge on me and I don't know anyone that I can borrow one from so I'll just ask here, what's the diameter of a sprinter strut?
And what inner diameter would I need on the sleeve?
I'm posting this because I've seen people posting 51mm and 50mm and I really don't know!
Thanks in advance
Dirty_Sanchez
Re: Sprinter struts + coilover sleeves measurements Fri, 02 September 2005 02:41 Go to previous messageGo to next message
the strut diameter is 2" so i'd imagine it would be closer to 51mm
xolent
Re: Sprinter struts + coilover sleeves measurements Fri, 02 September 2005 04:14 Go to previous messageGo to next message
oh okays, so what size would be ideal for the sleeves?
xolent
Re: Sprinter struts + coilover sleeves measurements Fri, 02 September 2005 14:56 Go to previous messageGo to next message
bump?
Steve-AE86
Ademelaide, SA
Re: Sprinter struts + coilover sleeves measurements Sat, 03 September 2005 12:43 Go to previous messageGo to next message
it's DEFINATELY 51mm.
i've made at least 15 sets of coilovers for ae86's.
51mm is the sleeve size i've bought, because my vernier calipers told me to. Wink
takai
Re: Sprinter struts + coilover sleeves measurements Sun, 04 September 2005 03:49 Go to previous messageGo to next message
Yeah, it may as well be 51mm, just measured up the two pairs i have here. Interestingly, Corona *T13/4* struts are the same diameter.
Technically its supposed to be 2" which is 50.8mm. Add the paint which is on there, and its buckleys and none to 51mm.
EDIT: I should say also that 99% of suspension components are in Imperial (*groan*), so 51mm sleeves are 2", and 63mm springs are 2.5" etc.
[Updated on: Sun, 04 September 2005 03:52]
xolent
Re: Sprinter struts + coilover sleeves measurements Sun, 04 September 2005 03:57 Go to previous messageGo to next message
Thanks for the response guys, muchly appreciated.
51mm is definately the size?
How much movement is there if I put these on? Or is it a bitch to get on in the first place and would need to make the strut extremely cold and the sleeve hot?
Thanks guys!
Steve-AE86;
just wondering... do you use steel or alloy sleeves? After a while would the thread on the alloy wear off?
Sorry for the question guys, really struggling to decide on what to choose!
Steve-AE86
Ademelaide, SA
Re: Sprinter struts + coilover sleeves measurements Sun, 04 September 2005 22:33 Go to previous messageGo to next message
personally, i've always used steel sleeves.
not that it would matter, cos they come with alloy locking nuts...
takai used alloy sleeves on his, and has had no probs. i spose it comes down to personal choice, and there's always the cost factor.
51mm!!!
takai
Re: Sprinter struts + coilover sleeves measurements Sun, 04 September 2005 22:49 Go to previous messageGo to next message
Yeah, i have alloy sleeves on mine. Hold up quite nicely, but you have to be slightly more careful with them. Ive seen someone damage the thread by trying to adjust a set with a hammer and screwdriver.
Didnt help that he put a big crack in the locking ring...
Anyway
2 inches = 50.8 millimetersRazz
yrhkira
June 2005
Re: Sprinter struts + coilover sleeves measurements Mon, 05 September 2005 03:28 Go to previous messageGo to next message
xolent and all,
No they are not 51mm outside diameter. They are 2.00 inch outside diameter and this is the way they should be refered to.
The stuts on AE86 and for that matter RA23/28/40 (same size) are made using imperial tube sizes.
So simply forget any talk of metric sizes when ordering parts.
If you order or have someone make a set, such as the Koni ones from www.importbitz.com.au order them as a set of 2 inch inside diameter sleeves and you will have no trouble sliding them onto the strut after removing the OEM spring platform.
Also any competant machine shop can work in imperial and metric if you plan to get them made. Make them steel as they are welded top and bottom to the stut.
Alloy sleeves need some other method of keeping them in place on the strut and I really don't understand from other comments how this is possible.
Regards
Rodger
takai
Re: Sprinter struts + coilover sleeves measurements Mon, 05 September 2005 04:28 Go to previous messageGo to next message
Why, thanks for saying everything already said in the thread. Rolling Eyes
xolent
Re: Sprinter struts + coilover sleeves measurements Mon, 05 September 2005 06:06 Go to previous messageGo to next message
You need to make a seat for the alloy sleeve to sit on.
Steel sleeves, has anyone's rusted and was very difficult to adjust?
Thanks for your comments guys, fucken love you guys!
.wolfwood
Gold Coast
February 2005
Re: Sprinter struts + coilover sleeves measurements Mon, 05 September 2005 06:27 Go to previous message
who makes the best Coilover sleves or it doesnt really matter, thanks ben.
Previous Topic:Turbo Timer Install
Next Topic:Greddy BCC 93-97 Turbo Supra okay for 1jz?
Current Time: Wed Nov 18 20:10:53 UTC 2026
Total time taken to generate the page: 0.0077519416809082 seconds
