Toymods » Tech & Conversions » GX81 coilover
mic*
July 2005
GX81 coilover Fri, 02 September 2005 05:39 Go to next message
Have jus bought 1989 GX81 Mark II c/w TEMS (working - WTF?). Wondering if someone can tell me a part no. for coil springs. Or else something equivalent & common...
Re: GX81 coilover Fri, 02 September 2005 05:55 Go to previous messageGo to next message
JZX81 coilovers.
Get from http://www.importbitz.com.au
mic*
July 2005
Re: GX81 coilover Fri, 02 September 2005 06:18 Go to previous messageGo to next message
ok, excuse the ignorance coz i have always loved toyotas but only recently have i started extending my knowledge beyond "wow! there's a supra"
Do you think your typical suspension crowd are gonna know what spring suits a jzx81 better than an gx81? I am assuming you are telling me anything with an x8 chassis???
So if that is right then the king spring parts KTRL-77 & KTRL-76 which are lowered coils to suit an MX83 will work???
The last number in the model code denotes a "variation" is that right? Variation to what?
Does having TEMS change the spring design?
I am looking to replace just springs for now, and squash up the TEMS shocks till they die...
Re: GX81 coilover Fri, 02 September 2005 06:26 Go to previous messageGo to next message
Replacing the coils with lowered coils (like Kings) is not the same as getting coilovers.
I'm not 100% if MX83 coils are the same diameter to GX81 coils.
The 1 or 3 in MX83/GX81 denotes a slight tweak.
It varies from car to car.
Some are suspension changes, some are chassis changes.
I'm presuming the difference in the X8 is due to the doors being frameless, and a slightly different rear window/boot.
mic*
July 2005
Re: GX81 coilover Fri, 02 September 2005 06:35 Go to previous messageGo to next message
yeah, should have known better than to say coilovers. Coil over what if im jus talking springs?
Anyway, if you think the variation is rear windscreen & pillar-less doors, then theorectically the abovementioned springs should fit?
Main concern is still whether TEMS fitted vehicles have different spring design.
Stefan
Hobart, Tas
Re: GX81 coilover Fri, 02 September 2005 06:36 Go to previous messageGo to next message
Fairly sure GX83 coilovers can be found on yahoo japan. May well require ditching the TEMS though, that's soemthing you'll have to figure out.
Re: GX81 coilover Fri, 02 September 2005 06:59 Go to previous message
TEMS should be fine, as far as I know they just use shocks with variable damping, the springs are fairly conventional. Of course, with coilovers, you're replacing the whole lot, so the TEMS has to go.
Previous Topic:Changing diff ratio's
Next Topic:Tacho Signal Converters "1JZ Conversion working"
Current Time: Thu Oct 22 13:37:14 UTC 2026
Total time taken to generate the page: 0.080530166625977 seconds
