Toymods » Tech & Conversions » W58 or R154??
1G-GTE KE70
W58 or R154?? Fri, 02 September 2005 07:06 Go to next message
Hey guys I was just wondering what gearbox I should use for my next drift car.
I am building another KE70 and need a gearbox that can handle 500hp. I'm not sure if W58's can handle that? and I've heard that R154's are a bit fragile?
Thanks for any imput. I'd prefer the W58 if it can handle it.
Re: W58 or R154?? Fri, 02 September 2005 07:15 Go to previous messageGo to next message
A W58 *might* be able to handle it because your car is fairly light (I'm assuming the KE70) and not *hugely* torquey (I'm assuming 1G here).
That said, you'd have to keep fresh oil in it, and you'd need a modicum of mechanical sympathy if it was to last behind that much power.
GTtwin
Newcastle, Australia
August 2005
Re: W58 or R154?? Fri, 02 September 2005 07:31 Go to previous messageGo to next message
I've seen R154's snap with alot less power than what alot of W58's have put through them. Also finding a 1G to R154 bellhousing may be a problem. Correct me if I'm wrong on this one guy's but I can't recall any 1G having an R154 behind it from the factory. Confused
1G-GTE KE70
Re: W58 or R154?? Fri, 02 September 2005 07:38 Go to previous messageGo to next message
hey it's not going to be a 1G or SR or anything under 2 litres... and no it's not going to be a 1JZ or any 6 cylinder.
any ideas? haha
but yeah it will have a fair bit of torque to it Very Happy
Re: W58 or R154?? Fri, 02 September 2005 07:44 Go to previous messageGo to next message
Turbocharged 1UZFE?
1G-GTE KE70
Re: W58 or R154?? Fri, 02 September 2005 11:53 Go to previous messageGo to next message
nope Cool
4 cylinder
brett_celicacoupe
townsville NQLD
Re: W58 or R154?? Fri, 02 September 2005 12:02 Go to previous messageGo to next message
1G-GTE KE70 wrote on Fri, 02 September 2005 17:38
any ideas? haha
22R Razz
kingmick
Banned by his request
moved to tamworth
Re: W58 or R154?? Fri, 02 September 2005 12:27 Go to previous messageGo to next message
go w58 because you are going to get very little of the power to the ground straight away with a ke70.
mick
1G-GTE KE70
Re: W58 or R154?? Fri, 02 September 2005 13:33 Go to previous messageGo to next message
tubbed rear will have 17x10 rims so getting power to ground will be no problem
brett it's not a 22R haha.
keep guessing. Razz
Re: W58 or R154?? Fri, 02 September 2005 13:37 Go to previous messageGo to next message
3RZFE. Actually, the size of the wheels isn't going to be a HUGE factor because it doesn't weigh enough to really use the tyres Razz
chrisellis
Re: W58 or R154?? Fri, 02 September 2005 13:45 Go to previous messageGo to next message
3s-gte?
terra
July 2005
Re: W58 or R154?? Fri, 02 September 2005 14:14 Go to previous messageGo to next message
chrisellis wrote on Fri, 02 September 2005 23:15
3s-gte?
thats in the 2 liter club my friend...
chrisellis
Re: W58 or R154?? Fri, 02 September 2005 14:21 Go to previous messageGo to next message
terra wrote on Sat, 03 September 2005 00:14
3s-gte?
this i know, read above "or anything under 2 litres". Under therefor should not rule out the 2 litre class, and hence 3sgte possibility.
1G-GTE KE70
Re: W58 or R154?? Fri, 02 September 2005 14:29 Go to previous messageGo to next message
3RZ-FE. Frank was right.
I'm buying a long motor from www.lcengineering.com
but yeah about that gearbox... W58?
terra
July 2005
Re: W58 or R154?? Fri, 02 September 2005 15:13 Go to previous messageGo to next message
1G-GTE KE70 wrote on Fri, 02 September 2005 17:08
any ideas? haha
some people only read what they want to see...
quest
u.s.a. south
Re: W58 or R154?? Fri, 02 September 2005 21:08 Go to previous messageGo to next message
Don't tacoma truck 4/6cyls already have a solid W gbox behind it ?
Probably only need forged pistons on prepped stock rods, in an otherwise stock motor.... so thats the path I'd go.
I'm sure it'll make enough torque to frighten you in that lightweight
I'm actually looking into the 3.4L tacoma v6, for a swap into an ae86. Full street car. Luv the smoothness. Will put down over 450 ft-lbs tq to the threads on pump gas!!... stock motor, stock ecu, t4 turbo.
Drivetrains are cheap. Just gotta see how "well" it'll fit
kingmick
moved to tamworth
Re: W58 or R154?? Fri, 02 September 2005 21:54 Go to previous messageGo to next message
sorry thought i read for drifting!you will go threw w58 very quick then.why do you want a manual box?
mick
p.s why guess?lmao for drag go an auto.
[Updated on: Fri, 02 September 2005 22:03]
supramickey
uk
September 2005
Re: W58 or R154?? Sat, 03 September 2005 09:49 Go to previous messageGo to next message
The W58 box wont last very long with 500hp going throught it ,
Your better of going with the r154.
1G-GTE KE70
Re: W58 or R154?? Sun, 04 September 2005 05:09 Go to previous messageGo to next message
it is for drifting.
I heard that R154's are fragile as well.
any suggestions?
petespipes
logan river brisbane
July 2005
Re: W58 or R154?? Sun, 04 September 2005 11:16 Go to previous messageGo to next message
trust toyota engineers?
What box do they put behind a powerful engine?
OR
take advice from your mates....
i think you can work it out.
monkeymajik
Re: W58 or R154?? Sun, 04 September 2005 11:30 Go to previous messageGo to next message
tubbed 17x10's for drifting in a ke70?
V8_MA61
Re: W58 or R154?? Sun, 04 September 2005 12:14 Go to previous messageGo to next message
1G-GTE KE70 wrote on Sun, 04 September 2005 15:09
it is for drifting.
any suggestions?
there is a frail part in the r154 called the 1st gear thrust washer. Replace this with a case hardened unit such as mine which cost $80, and you are away. The gears in them look like diff gears - fucking massive! i have one behind my worked ford v8...will remain to be seen as to how it likes launches and bottom end torque Smile
petespipes
July 2005
Re: W58 or R154?? Sun, 04 September 2005 13:22 Go to previous messageGo to next message
A brisbane based ford mustang importer who also does big blocks purchased an ex 7m r154 off me.He said he has used them behind big V8,s with good results [relevant to their cost]
Blakes advice on the thrust washer is a definite if you plan to shock load the box.[we know you will] Smile
1G-GTE KE70
Re: W58 or R154?? Wed, 07 September 2005 07:04 Go to previous message
R154 it is.
Thanks for everyones imput.
monkey: yes the rear will be tubbed for 17x10's. 2 reasons, firstly there are way more performance tyre sizes available in 17's than just 205/55R15's. secondly, more second hand performance tyres in 17" as well.
Previous Topic:S-Series diff into a KE70
Next Topic:MA61 1UZ 4WD Conversion??
Current Time: Fri Nov 20 12:37:49 UTC 2026
Total time taken to generate the page: 0.17647218704224 seconds
