Classifieds » Wheels, Tyres, Suspension and Brakes » [SOLD] AE86 Brake Upgrade: RX7 Series 4 Calipers
AEeightysix
Baulkham Hills, Sydney
[SOLD] AE86 Brake Upgrade: RX7 Series 4 Calipers Fri, 02 September 2005 07:41 Go to next message
Abandoned Project due to lack of funds.
Package includes Calipers, Pads and Pins.
$300 postage extra
Shown below is the caliper.
http://img209.echo.cx/img209/5258/brakecaliper0041wb6pe.jpg
You just need the bracket made up.
Race Brakes in Sydney is where i enquired about this conversion.
[Updated on: Thu, 29 September 2005 12:23]
Evan
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Fri, 02 September 2005 10:25 Go to previous messageGo to next message
Oh no dude. they should be still nicely painted?
Didn't have em for long
ae86 Drifter
newcastle
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Sat, 03 September 2005 04:53 Go to previous messageGo to next message
damm wish i had the funds,id buy them just like that
if there still round in couple of weeks ill nab them
Wezelton
Sunshine Coast
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Sat, 03 September 2005 22:01 Go to previous messageGo to next message
Do you think they would fit ra60/65 struts ? i've read up on the upgrade for sprinter, but im looking for an upgrade for my celica..
AEeightysix
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Sun, 04 September 2005 02:36 Go to previous messageGo to next message
Wezelton wrote on Sun, 04 September 2005 08:01
I'm sure that would work if you re-designed the adapter plate.
Pull your strut apart and have a look at your current plate and compare them to the drawings ae86-drift is hosting.
AEeightysix
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Sun, 04 September 2005 02:40 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&g oto=636691&rid=4675&S=d9d34896fe915abe0658 a42ad99efb59
Wezelton
Sunshine Coast
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Sun, 04 September 2005 09:03 Go to previous messageGo to next message
It does look like a heap of effort.. especialy since my celica out brakes my friends S13 Neutral im running 14-175x65 front n 15-195x50 tires, he has 15-205x60's all round.. Maybe im just better than the datsun driver hahah yeah toyota!
yrhkira
June 2005
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Mon, 05 September 2005 05:02 Go to previous messageGo to next message
Can you supply:-
Mounting hole spacing?
Offset as you have mounted, to centreline of caliper?
Offset from outside of mounting surface to caliper centreline?
I have brackets that may work. So could be interested.
Regards
Rodger
AEeightysix
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Thu, 08 September 2005 05:51 Go to previous messageGo to next message
yrhkira wrote on Mon, 05 September 2005 15:02
Can you supply:-
Regards
Rodger
I can supply the mounting hole spacing.
How can i supply the offsets if i've never had them mounted?
yrhkira
June 2005
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Thu, 08 September 2005 06:03 Go to previous messageGo to next message
Ok,
Of course, silly me the pitures of it mounted are from somewhere else.
Could you please then measure the distance from the inside of the mounting hole surface to the centerline of the caliper. Basically the distance from the surface where your thumb is holding it as shown in your picture.
Does not need to be acurate, within a couple of millimetres will be fine.
Regards
Rodger
Dirty_Sanchez
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Thu, 08 September 2005 08:02 Go to previous messageGo to next message
i got a set of these brakes on my sprinter. the response on these things is remarkable Shocked
AEeightysix
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Thu, 08 September 2005 09:16 Go to previous messageGo to next message
Mounting hole distance = 16cm
Inside Mounting hole to centreline = 3cm
Centre line to exterior edge (facing)= 7cm
Centreline to interior edge (brake lines) = 8.5cm
Length = 21cm
Width = 15.5cm
Thickness = 7cm
AEeightysix
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Wed, 14 September 2005 09:55 Go to previous messageGo to next message
still here... Rolling Eyes
cnic82
January 2005
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Wed, 14 September 2005 13:33 Go to previous messageGo to next message
I've got a set of 280mm silvia rotors to suit this conversion, pm me if anyone is interested
Craigy
WaLLLY
SW Sydney
February 2005
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Wed, 14 September 2005 23:17 Go to previous messageGo to next message
nice hijack!^^ Rolling Eyes
Bananaman
Strathfield / Sydney
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Thu, 15 September 2005 02:10 Go to previous messageGo to next message
AEeightysix did the same to him first mate, horses for courses Wink
yrhkira
June 2005
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Thu, 15 September 2005 06:59 Go to previous messageGo to next message
AEeightysix,
Thanks for the numbers. They are just what I needed to know.
I'll take them away and compare to what I have got.
Let you know what I find and then make a decission.
Regards
Rodger
yrhkira
June 2005
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Fri, 16 September 2005 06:01 Go to previous messageGo to next message
AEeightysix,
Checked what I had and what I am toying with at home.
I would need to do to much work with a couple of brackets I have already to justify buying the calipers this time round. I know what I could do though, in theory to make them fit.
Got to try and recoup some dollars on a couple of my brake conversions now.
Thanks again for the measurements.
Regards
Rodger
AEeightysix
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Sat, 17 September 2005 03:15 Go to previous messageGo to next message
dogged... Shocked
ae86 Drifter
newcastle
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Sun, 18 September 2005 03:11 Go to previous messageGo to next message
i wish i could afford these,damm g/box and catalitic convertor Mad Mad
AEeightysix
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Mon, 19 September 2005 07:47 Go to previous messageGo to next message
Offers accepted, I need these gone!!
LeZZa
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Thu, 22 September 2005 09:03 Go to previous messageGo to next message
If $300 including postage to Adelaide is ok, i'll take them.
ae86 Drifter
newcastle
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Fri, 23 September 2005 02:16 Go to previous messageGo to next message
give me a week.fixed my cat now just gotta buy g/box first
AEeightysix
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Fri, 23 September 2005 04:03 Go to previous messageGo to next message
LeZZa wrote on Thu, 22 September 2005 19:03
Pending payment
AEeightysix
Re: AE86 Brake Upgrade: RX7 Series 4 Calipers Thu, 29 September 2005 03:20 Go to previous message
sold'ski
Previous Topic:sx front calipers and hubs
Next Topic:15" rims for SALE
Current Time: Wed Oct 28 02:00:52 UTC 2026
Total time taken to generate the page: 0.014556884765625 seconds
