Classifieds » Car/Engine Electronics & Audio » FS: JL 250/1 Monoblock Amplifier *as new*
CeLiCa
FS: JL 250/1 Monoblock Amplifier *as new* Fri, 02 September 2005 07:48 Go to next message
In perfect as new condition.
Hardly ever used.
No scratches on amp.
Cost $770 new.
Located in Melb, but will post interstate.
$400ono
Here are specs:
Product Description:
* Class D Circuitry
* 250W RMS @ 1.5 ohms - 4 ohms
* THD at Rated Power: 95dB below rated power
* Frequency Response: 5 - 50,000 Hz (+0, -1dB)
* Damping Factor: >500 @ 4 ohm/50 Hz
* Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
* Differential-Balanced Input Topology: (1 pair of inputs)
* On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
* Preamp Output: 2-channel (full-range, LP or HP)
* Bass EQ: variable boost up to 15dB
* Infrasonic Filter: defeatable 24dB/octave at 30 Hz
* Signal-Sensing Turn-On: permits operation without remote lead
* Dual mono speaker output connections: accept up to 8ga. wire
* +12V and Ground connections: accept up to 4ga. Wire
* Dimensions: 10.25'L x 9.25'W x 2.36'H
Amplifier Specifications:
* Number of Channels 1 - Mono
* RMS Power (4 ohms) 250 watts
* RMS Power (2 ohms) 250 watts
* RMS Power (1 ohm) N/A (1.5 ohm stable)
* Bridged RMS Power N/A
* Peak Power Output 500 watts approx.
* Min. Impedance Unbridged 1.5
* Min. Impedance Bridged N/A
* THD @ Rated RMS Power 0.05%
* Speaker Level Inputs No
* Amp Preamp Outputs Yes
* Built-in Crossover LP
* Bass Boost 0 - 15dB
* Signal-to-Noise Ratio >95dB
* Fan Cooled No
* Fuse Rating N/A
* Warranty 1-year SE
http://firesport.ipspace.com/item_images/25333.jpg
RA28GT
Adelaide, SA
Re: FS: JL 250/1 Monoblock Amplifier *as new* Fri, 02 September 2005 08:12 Go to previous messageGo to next message
Thats a quailty amp right there mate, good luck with the sale Very Happy
Wouldnt happen to want to buy my 500/1 would ya? Laughing Laughing
CeLiCa
Re: FS: JL 250/1 Monoblock Amplifier *as new* Fri, 02 September 2005 08:43 Go to previous messageGo to next message
Thanks mate... I found that the 250/1 was enough power for my setup.
Good luck on your sale too!
CeLiCa
Re: FS: JL 250/1 Monoblock Amplifier *as new* Mon, 05 September 2005 05:16 Go to previous message
bump, price is negotiable
Previous Topic:SUB BOX for sale CHEAP
Next Topic:550CC original US Spec Supra injectors Purpletop Sidefeed
Current Time: Thu Oct 29 12:56:49 UTC 2026
Total time taken to generate the page: 0.0059051513671875 seconds
