Toymods » General Car Talk » I will Pay for someone to Setup a SAFC (dial Version) in Melb!!
TRD-ST162
I will Pay for someone to Setup a SAFC (dial Version) in Melb!! Fri, 02 September 2005 08:08 Go to next message
Does anyone know how to setup this bloody thing?
I've got a safc version 1 with the dials, no screen and i can't understand the white switches on the back and also the car setting...
I'm also tryin to setup a Super ITC in my car..
I'm tryin to find out how to set these both up for a 3SGE Gen 1 in a toyota celica st162 SX!
sated
Re: I will Pay for someone to Setup a SAFC (dial Version) in Melb!! Fri, 02 September 2005 15:12 Go to previous messageGo to next message
Youre going to need the info (should come with it) - to set the dip switches etc in the back of the module to match the sensor output for your specific car / engine. And youre also going to need the pin out info of the harness (ECU).
Wiring it from there shouldnt be too hard. Just note that in some cases, sensor ground is not the same as electrical ground.
Good luck.
ae86drift
sydney.au
Re: I will Pay for someone to Setup a SAFC (dial Version) in Melb!! Fri, 02 September 2005 15:37 Go to previous messageGo to next message
step 1. ebay it.
step 2. buy a safc2
step 3. ????
step 4. profit.
b05c0
Re: I will Pay for someone to Setup a SAFC (dial Version) in Melb!! Sat, 03 September 2005 00:41 Go to previous messageGo to next message
try there.... you still need to know wiring harness config. on you ECU.
http://www.alltrac.net/manuals/SAFC.htm
TRD-ST162
Re: I will Pay for someone to Setup a SAFC (dial Version) in Melb!! Sat, 03 September 2005 07:52 Go to previous messageGo to next message
Thats a better version of what i had, thanx for that..
Well what i suspected was to setup the SAFC the same way all the other 3SGE were set..
Even the 4age was set the same..
Can everyone see a pattern?
its UP DOWN UP UP DOWN UP DOWN UP
(UP IS WHERE THE WHITE IS TO THE TOP)
And all the cars are selected as 3
I found out how to setup the Super itc.. All the switches are set to UP and Car setting is 0
Just gotta make sure about this one
Wiring isn't bad, I can follow each wire from the loom no probs
Thanx again!
st184 sillycar
Re: I will Pay for someone to Setup a SAFC (dial Version) in Melb!! Sat, 03 September 2005 08:10 Go to previous messageGo to next message
NIZPRO Bro.
They charge like a wounded bull, but Simon's good, and He's quick - so even though the hourly rate is up there, you should be in and out with the SAFC and S-ITC. Once He's set your knobs, MARK THEIR POSITION so that if they're ever bumped (or you wanna play) you can "get back home" Razz
Ping is baadddd, mmmmmokaaayy..
b1gb3n
south Melbourne/KL
Re: I will Pay for someone to Setup a SAFC (dial Version) in Melb!! Sun, 04 September 2005 13:41 Go to previous message
TRD-ST162 wrote on Sat, 03 September 2005 17:52
Thanx again!
i dontthink theres a pattern to the settings adrian. u will need an O2 sensor for the safc settings. no not the a/f ratio gauge, the good $500 ones
if ur interested, my 4age idles at -24% (lean) on the safc
Previous Topic:FMIC In QLD
Next Topic:3SGE parts in GT4 gearbox?
Current Time: Wed Nov 18 20:53:53 UTC 2026
Total time taken to generate the page: 0.0076298713684082 seconds
