Toymods » Tech & Conversions » 2tg firing order
ae71 kid
melbourne
August 2005
2tg firing order Fri, 02 September 2005 08:31 Go to next message
hi guys,
i need to kno quickly how the 2tg firing order goes?
its all bolted in ready to go but wont start due to my brother messing it up!!
cheers in advance guys
Buster
Re: 2tg firing order Fri, 02 September 2005 10:09 Go to previous messageGo to next message
1-3-2-4 I think ???
[Updated on: Fri, 02 September 2005 10:10]
pheonix83
Devonport Tasmania
Re: 2tg firing order Fri, 02 September 2005 10:11 Go to previous messageGo to next message
1342
SIKTA22
Re: 2tg firing order Fri, 02 September 2005 11:21 Go to previous messageGo to next message
what pheonix83 said..
YelloRolla
On your mum!
Re: 2tg firing order Fri, 02 September 2005 14:22 Go to previous messageGo to next message
Phoenix is correct 1-3-4-2
September_Squall
Melbourne, Australia
March 2005
Re: 2tg firing order Fri, 02 September 2005 14:46 Go to previous messageGo to next message
Can I say 1342 as well?
Most common 4 stroke 4 cylinder auto motors are 1342.
yrhkira
June 2005
Re: 2tg firing order Mon, 05 September 2005 03:42 Go to previous messageGo to next message
That is the correct order (1342)
And if that does not get the motor running the distributor rotor may be 180 degrees out.
At top dead centre (TDC) cylinder one compression/firing, the rotor should point to where the number one plug lead sits on the cap.
I get it wrong about one out of ten goes when not careful after turning the motor over without the dizzy in place.
Regards
Rodger
ae71 kid
melbourne
August 2005
Re: 2tg firing order Mon, 05 September 2005 10:03 Go to previous messageGo to next message
thanks guys, its all going good except that i have no idea what timing to run????? ive tuned it to how it runs best but the scope at work says its running like 20 deg BTDC, that sounds way too advanced to me and i cant hear if its pinging cos its not running any exhaust atm? any 1 know correct timing 4 a 2tg?
cheers tim
yrhkira
June 2005
Re: 2tg firing order Tue, 06 September 2005 01:38 Go to previous messageGo to next message
ae71 kid,
Good to hear you got the motor running.
20 degrees is a lot if that is the idle timming.
If I recall correctly there should be two marks on the crank pulley. The first to come around is the timming mark and the next is TDC. There should be a mark or pointer on the timing chain cover to reference too.
The factory static timing works out to be 12 degrees BTDC and about that at an idle of 900 odd rpm.
If you plan to use normal (low RON) pump ULP drop back to 10 degrees static.
I think, without going back to the manual (which is at home) the distributor should run to around 24 degrees of maximum advance.
Hope this is of help
Regards
Rodger
rthy
Melbourne - NthSubs
Re: 2tg firing order Tue, 06 September 2005 04:02 Go to previous messageGo to next message
would this be the same as the 4age?
Henn
Rosanna, Melb
Re: 2tg firing order Tue, 06 September 2005 04:21 Go to previous messageGo to next message
Yes
ae71 kid
melbourne
August 2005
Re: 2tg firing order Tue, 06 September 2005 10:25 Go to previous message
thanks mate, what u mean by 24 degs of max dizzy advance? does that have something to do with the little nob on the dizzy? also anyone got clues on how to tune twin solexes? im sure im running way rich?
cheers tim
Previous Topic:1uz turbo claims
Next Topic:k50-k40 measurements
Current Time: Fri Oct 23 16:34:11 UTC 2026
Total time taken to generate the page: 0.0069091320037842 seconds
