Toymods » Tech & Conversions » No RPM reading or Spark with wolf on 1ggze
rx793
Perth, Western Australia
No RPM reading or Spark with wolf on 1ggze Fri, 02 September 2005 11:05 Go to next message
Hey guys, i hooked the up the CAS as instructed, and ive set sync and reference up, and still no spark, and also its plugged into the PC laptop and gives no RPM reading when cranking it over. Any ideas?
Re: No RPM reading or Spark with wolf on 1ggze Fri, 02 September 2005 14:48 Go to previous messageGo to next message
get multimeter and check that CAS is producing signal that ECU can use.
Re: No RPM reading or Spark with wolf on 1ggze Sat, 03 September 2005 14:11 Go to previous messageGo to next message
Add the AEM 'signal conditioner' box, check your wiring, and check the software settings. Wolf's always take a few goes to get working...
Re: No RPM reading or Spark with wolf on 1ggze Sun, 04 September 2005 00:58 Go to previous messageGo to next message
anyone got one of these AEM signal conditioners i can "abuse" for a while?? I want to make my own Razz
gearb0x
Re: No RPM reading or Spark with wolf on 1ggze Sun, 04 September 2005 04:48 Go to previous messageGo to next message
THE WITZL wrote on Sun, 04 September 2005 10:58
nope. but check out msefi.com/megasquirt.com there are a few working circuits knocking around to shape VR circuits Smile
rodney
south africa
August 2005
Re: No RPM reading or Spark with wolf on 1ggze Sun, 04 September 2005 08:09 Go to previous messageGo to next message
Hi, i had the same problem with my 3d, it could not pick up the trigger 2 to sync the system, but try spinning the dizzy with a drill, magic, everything works, eventually i converted mine to a 4+1 hall sender, car is now running, even with the std gze igniters, try the very low setting for trigger2, falling edge
Henn
Rosanna, Melb
Re: No RPM reading or Spark with wolf on 1ggze Sun, 04 September 2005 23:52 Go to previous message
I have a Wolf 3D V4 running a 4AGZE and have never had any problems with CAS hookup (admittedly I did have help from a friend who worked at AEM when configuring it).
If anyone wants the configuration PM me your email address and I'll send it to you. Or if someone can host it for me then please make yourself known.
Hen
EDIT - Oh, and make sure the pickups are adjusted as close as humanly possible to the toothed wheels.
[Updated on: Sun, 04 September 2005 23:54]
Previous Topic:How much power can a Supra/Celica gearbox handle?
Next Topic:O2 sensor
Current Time: Sun Oct 25 04:38:00 UTC 2026
Total time taken to generate the page: 0.005836009979248 seconds
