Toymods » Tech & Conversions » How to get AE86 Zenki Parkers/headlights look Kouki
nightdevil
Wollongong
How to get AE86 Zenki Parkers/headlights look Kouki Sat, 03 September 2005 07:18 Go to next message
What you need: Masking Tape
Acrylic Black Paint (Pressure Pack)
Wax and Grease Remover
Step 1: Mask the parkers like this
http://img361.imageshack.us/img361/1175/10005709fv.th.jpg
Step 2: Wipe the unmasked area where your going to paint with Wax/Grease Remover
Step 3: Apply the paint to the unmasked area of the parkers
http://img361.imageshack.us/img361/1064/10005766cu.th.jpg
http://img361.imageshack.us/img361/4862/10005777zd.th.jpg
Step 4: Mask up the headlights leaving the tops and bottoms
NOTE: In this picture i used primer to see if it would work on glass. Not a good idea. It just peels off. Just wipe Wax/Grease remover over the areas you need to paint then just spray straight on.
http://img392.imageshack.us/img392/5425/10005716sb.th.jpg
Step 5: Apply the paint on the headlights
http://img392.imageshack.us/img392/8090/10005817rj.th.jpg
http://img392.imageshack.us/img392/549/10005805yg.th.jpg
And...
http://img389.imageshack.us/img389/4642/10005854lq.th.jpg
http://img389.imageshack.us/img389/6127/10005867iu.th.jpg
http://img389.imageshack.us/img389/1539/parker1bt.th.jpg
Alot cheaper than getting the actual Kouki parkers and Eyebrows.
[Updated on: Sat, 03 September 2005 10:09]
ZZT231
melbourne.vic.au
Re: How to get AE86 Zenki Parkers/headlights look Kouki Sat, 03 September 2005 07:41 Go to previous messageGo to next message
Anyone correct me if I'm wrong but, wouldn't you use high temperature paint as it may peel from the heat off the lens?
Good write up! Simple, easy and affordable...
takai
Re: How to get AE86 Zenki Parkers/headlights look Kouki Sat, 03 September 2005 07:48 Go to previous messageGo to next message
Lenses dont get that hot. Sure they get hot, but not the temps where paint will peel.
HTP is made for exhausts and brakes, where it gets VERY hot, not just warm.
DRFT - 86
Batemans Bay, NSW
February 2005
Re: How to get AE86 Zenki Parkers/headlights look Kouki Sat, 03 September 2005 09:43 Go to previous messageGo to next message
nice work chief...
.wolfwood
Gold Coast
February 2005
Re: How to get AE86 Zenki Parkers/headlights look Kouki Sat, 03 September 2005 09:50 Go to previous messageGo to next message
my head lights already have a black plastic part were you painted at the top and bottom, does that mean there not aus spec?
i only payed 220$ for both lights.
nightdevil
Wollongong
Re: How to get AE86 Zenki Parkers/headlights look Kouki Sat, 03 September 2005 10:06 Go to previous messageGo to next message
.wolfwood wrote on Sat, 03 September 2005 19:50
Are they an actual panel? screwed onto the tops of the headlights. Do they have the brackets on the sides for the foglights?
.wolfwood
Gold Coast
February 2005
Re: How to get AE86 Zenki Parkers/headlights look Kouki Sat, 03 September 2005 10:21 Go to previous messageGo to next message
im not sure about the fog lights but the blact plastic strips are sorta click on and serewed on. i will have a lok when i get my car back from the shop
ShiRi
Re: How to get AE86 Zenki Parkers/headlights look Kouki Sat, 03 September 2005 12:58 Go to previous messageGo to next message
Well done Craig... it's better than what i had before i did it properly... GO ELECTRICAL TAPE
this looks much neater...
but nothing tops the way it should be Razz
easiest way to check if its a JDM headlight is if there is a metal cap inside the headlight infront of where the globe goes... nothing there = jdm... cap there = aus-spec
takai
Re: How to get AE86 Zenki Parkers/headlights look Kouki Sat, 03 September 2005 15:05 Go to previous message
ShiRi wrote on Sat, 03 September 2005 22:58
Not necessarily, my AuDM headlights do not have a glare filter infront of the globe. They are definately AuDM headlights as well, as they do not have the foglight brackets, nor the JDM grill brackets.
Previous Topic:Z20 sunroof
Next Topic:KE35 4x4 offroad
Current Time: Fri Nov 20 19:24:16 UTC 2026
Total time taken to generate the page: 0.005540132522583 seconds
