Toymods » Tech & Conversions » Engine bay diagnostic box...
wilbo666
Engine bay diagnostic box... Sun, 04 September 2005 12:14 Go to next message
Ok can someone explain to me what all the points in the engine bay diag box do? Razz
This would be good tech information to have (as the answers become apparent I will try and update this thread, or construct a PDF with all the information in it Smile)
(JZZ30 Engine Diag box DLC1)
http://everest.fit.qut.edu.au/~n4150414/JZA61/Random/tn_DSC01874.JPG
Fp -> Fuel Pump
W -> Check engine light (note that the actual pin is missing Razz great, why toyota leave it out is beyond me)
E1 -> Ground
CC0 -> Exhaust Gas Temperature (The Witzl)
TE1 -> Ground to transmit codes out W
TE2 -> Ground to transmit serial data out VF1
+B -> ECU Switched Battery voltage
VF1 -> Learned Voltage Feedback (TE1 OFF)
Voltage Feedback (TE1 ON, IDL/CTP off)
Serial Data when TE2 is grounded (if OBD with serial)
VF2 -> ? (ODB-II?)
OX1 -> 1st Oxygen sensor output
OX2 -> 2nd Oxygen sensor output (1uz-fe)
AB -> ?
OP1 -> ?
CC2 -> ?
Ts -> ?
Tt -> ?
TEM -> TEMS?
OP2 -> ?
OP3 -> ?
IG- -> Igniter Tacho Output Signal (5V square wave)
WA -> ?
WB -> ?
(a lot of these are marked with no actual pins on the JZZ30 diag box Smile)
Some of the information I have collected comes from the toyota technical description manuals (available at www.autoshop101.com)
Help me fill in the blanks people Smile
[Updated on: Sun, 04 September 2005 14:14]
Re: Engine bay diagnostic box... Sun, 04 September 2005 12:40 Go to previous message
CCO - exhaust temp sensor warning light thingy
Previous Topic:4AGE knock sensors
Next Topic:fuel rail upgrade?? 3s
Current Time: Fri Oct 23 02:07:01 UTC 2026
Total time taken to generate the page: 0.019648790359497 seconds
