Toymods » Tech & Conversions » Upper control arm bolts
Upper control arm bolts Sat, 28 December 2002 10:35 Go to next message
Sorting out the suspension on my Corona Mk2, and I need to undo the upper conrtol arm bolts. There is minimal clearance between them and the bodywork, and the manual suggests I use an SST to undo them.
They are on tight, and look like they have never been undone in the last 27 years. I have saturated them with WD40, and have cut down a spanner to get in there a try to undo them (with hammer persuasion) to no avail.
Any helpful hints? Car is non mobile.
Cheers Dave.
celicamad85
Banned member
Re: Upper control arm bolts Sat, 28 December 2002 10:46 Go to previous messageGo to next message
whenever i get stuck on a nut or bolt that wont come unstuck i have a long pipe which i use to slip over the end of the wrench or spanner, like a leverage
sst...whats the stand for again...special service tool ?
in the toyota manual i have there is a million sst's and they are all refered to as being sst so they dont really help there only by saying we have a special tool to use that you dont !
Re: Upper control arm bolts Sat, 28 December 2002 11:07 Go to previous messageGo to next message
SST = special service tool
Yep I have my own very special 4' long piece of 2" water pipe that is my breaker bar extender. Unfortunately, there isn't the room to use it!
Might just bolt it all together and take it to an alignment place and plead ignorance.
ed_ma61
Lost in the K hole
Re: Upper control arm bolts Sat, 28 December 2002 11:34 Go to previous messageGo to next message
dave, car on jack stands, lay under car with pipe, scream, kick and wail about... thats what was required on my rear trailing link bolts in a similar location/relation to body panels etc...
kicking the breaker pipe seems to work a treat...
keep at it, and you just want to cry tears of joy when you hear that ellusive *click*
hehehe
ed
Re: Upper control arm bolts Sat, 28 December 2002 12:15 Go to previous messageGo to next message
Just to show you what I mean, here is a pic. The bolts are facing inwards towards the inner guard, and there might be 2cm total room behind there. The fancy contraption is the aforementioned SST. Hate to see what one of those costs from Toyota if still available.
http://members.optusnet.com.au/gianttomato/JZX23/Corona%20Mk2%20manual%20UCAa.jpg
Still open to suggestions.
Cheers Dave.
jase
Re: Upper control arm bolts Sun, 29 December 2002 07:34 Go to previous messageGo to next message
Whats the number on the sst.
Re: Upper control arm bolts Sun, 29 December 2002 08:15 Go to previous messageGo to next message
09647-22010.
EDIT: not available from Toyota anymore. The parts guy laughed.
[Updated on: Tue, 31 December 2002 05:16]
Re: Upper control arm bolts Tue, 31 December 2002 03:54 Go to previous messageGo to next message
Well after 3 days of constant WD40 soakage, and a few phone calls to alignment places with the end result of laughter, I found a 19 mm dwarf ring spanner. This actually fit in the gap, and, with a little persuasion from a brickie's hammer, I was able to undo the 4 pesky bolts.
Thanks all.
Bugman
Re: Upper control arm bolts Tue, 31 December 2002 04:55 Go to previous messageGo to next message
better you got up and danced when you got it off.
Re: Upper control arm bolts Tue, 31 December 2002 05:14 Go to previous messageGo to next message
Yep, there was much elation! Very Happy
jase
Re: Upper control arm bolts Wed, 01 January 2003 06:16 Go to previous messageGo to next message
Great!
I was getting a bit sick of looking through the pile of old sst's.
Re: Upper control arm bolts Wed, 01 January 2003 06:26 Go to previous messageGo to next message
You have a pile of old SSTs?
Where are you? Please say Melbourne.
jase
Re: Upper control arm bolts Thu, 02 January 2003 00:13 Go to previous message
Um........yeh. kinda.
They're not always put back in their boxes, but, so its kinda hard to find.
Don't get too excited, all the times I've looked for one I needed I've only found he right one a couple of times.
There alot in the pile, but there were HEAPS available. Less so on the newer cars....better design etc. I guess.
Sorry, not Melbourne.
If you want to know more, pm.
Previous Topic:4age compression check
Next Topic:Conversion Questions
Current Time: Tue Oct 27 00:44:45 UTC 2026
Total time taken to generate the page: 0.0048911571502686 seconds
