Classifieds » Parts Wanted » URGENT: I Need Suspension - FOUND!
Paranoid Android
Sydney NSW
August 2005
URGENT: I Need Suspension - FOUND! Sun, 04 September 2005 23:23 Go to next message
Parts found,
[Updated on: Thu, 08 September 2005 11:46]
terra
July 2005
Re: URGENT: I Need Suspension Mon, 05 September 2005 01:48 Go to previous messageGo to next message
have you tried a tyre shop to see if they can just do a wheel alignment?
sometimes its just something gone loose.
i understeered into a kerb at 80kph, buclked both wheels on that side and it wobbled liked hell (About 5cm of movement at 10kph) with straight wheels back on.
a wheel alignment fixed my algnment problems Razz
God was on my side as if i had climbed the kerb i wouldve hit a pole Surprised it wasnt even a hard kerb either.. one of those 45 degree angle ones that you can drive up slowly
beerhead
January 2005
Re: URGENT: I Need Suspension Mon, 05 September 2005 03:04 Go to previous messageGo to next message
If the shock's or springs have any damage you'll want to swap them in pairs. By the sounds you may have only bent the mounts, so depending on how far out it is, you may be ablt to do like terra said, or bend the mounts back some what and get it done. Is the control arm bent? Ah well best of luck mate.
Paranoid Android
Sydney NSW
August 2005
Re: URGENT: I Need Suspension Mon, 05 September 2005 03:23 Go to previous messageGo to next message
everything looks straight when i take the wheel off
however when i get someone to turn the steering both ways the shock and spring assembly rotates off center
when i put the wheel back on it looked much better (the shocks had let the hub down while it was jacked) its difficult to see whats broken or bent cos everthing looks straight!!
Paranoid Android
Sydney NSW
August 2005
Re: URGENT: I Need Suspension Mon, 05 September 2005 10:44 Go to previous message
thanks for the advice guys, the quote came back as $1200 Sad
apparently the chassis moved, knuckles are broken, steering bent, torque box damaged Embarassed
will see it tomorrow to decide what to do, but i think i need a suspension trnasplant and alignment,
Previous Topic:WTB Rolling crown body
Next Topic:Gearbox wanted E58-11C LSD
Current Time: Fri Oct 23 23:57:10 UTC 2026
Total time taken to generate the page: 0.0042967796325684 seconds
