Toymods » Tech & Conversions » I need a TPS for a 3TGTE, what'll Fit??
ta2272
icon2.gif  I need a TPS for a 3TGTE, what'll Fit?? Mon, 05 September 2005 01:48 Go to next message
Hey guys my 3tgte does not have a throttle position sensor and i really need to get my hands on one, does anyone know one which will go close to fitting it or an ideas for it.
Jason
ta2272
Re: I need a TPS for a 3TGTE, what'll Fit?? Mon, 05 September 2005 06:03 Go to previous messageGo to next message
shaft size is 8mm,
Steve M
Re: I need a TPS for a 3TGTE, what'll Fit?? Mon, 05 September 2005 06:53 Go to previous messageGo to next message
Tough question, that one.
I've never seen one but I reckon they'd be of the same design as the 18RG ones.
Is it a squarish 3 pin box or a round 4 pin box?
The hardest thing will be to match up the internals, if it is a three pin square box then you'll find something that fits no worries.
The internals have numers written on them, as does the outside casing I think. The outside casing is a rough number, the internals have the actual number written on them.
This number is the throttle degree reading that the TPS gives out.
These differ from one engine to another.
Here the two that I've looked at:
5ME: 60 degrees (on casing), 58.5 (on internals)
18RGEU: 20 degrees (on casing), 18.5 (on internals)
They all have 8mm shafts.
These degree numbers are the movement intervals at which the TPS signal changes for accelleration.
I don't know if that will help you, but it might.
Get someone with a 3TGTE to check what degree number is written on theirs and see if you can find one with the same number on some other throttle body.
lilcrash
ipswich queensland
Re: I need a TPS for a 3TGTE, what'll Fit?? Mon, 05 September 2005 07:59 Go to previous messageGo to next message
im not sure about the 3tgte but on my 2tgeu in using one off a falcon. the only prob i have is that on no accel my tps is at 20%, i have a haltech so it doesnt matter but yer just so u know
good luck
laterdays
brett_celicacoupe
townsville NQLD
Re: I need a TPS for a 3TGTE, what'll Fit?? Mon, 05 September 2005 10:16 Go to previous messageGo to next message
i got a 5ME TB if you want it
ta2272
Re: I need a TPS for a 3TGTE, what'll Fit?? Mon, 05 September 2005 11:49 Go to previous messageGo to next message
brett_celicacoupe wrote on Mon, 05 September 2005 20:16
and what is that???
Re: I need a TPS for a 3TGTE, what'll Fit?? Mon, 05 September 2005 23:16 Go to previous messageGo to next message
Are u after a switch style, or variable style for aftermarket ecu? 5ME for example is switch style. No good for aftermarket ecu.
rb20det
Re: I need a TPS for a 3TGTE, what'll Fit?? Tue, 06 September 2005 06:29 Go to previous messageGo to next message
new from toyota there about $280 takes 4- 6 weeks for delivery
ta2272
Re: I need a TPS for a 3TGTE, what'll Fit?? Wed, 07 September 2005 07:05 Go to previous messageGo to next message
nissan fj20 tps fit perfectly but it is a swithc kind
Re: I need a TPS for a 3TGTE, what'll Fit?? Wed, 07 September 2005 09:21 Go to previous messageGo to next message
you can buy new ones from ppl like wolf/haltech, but they are cheaper from Farnell (rotary position switches i mean..)
Re: I need a TPS for a 3TGTE, what'll Fit?? Wed, 07 September 2005 10:58 Go to previous message
I concur with oldcorollas
Previous Topic:AE82 rear calipers fit jap spec rear discs?
Next Topic:my (almost) mighty sprinter
Current Time: Fri Nov 20 16:35:18 UTC 2026
Total time taken to generate the page: 0.064234972000122 seconds
