Toymods » Tech & Conversions » Just brought a 1980 Celica, then what do I do now?
Spike
Just brought a 1980 Celica, then what do I do now? Wed, 05 June 2002 04:55 Go to next message
Hey all,.. I just brought a celica for 600 bucks! no rust, engine is good, just a bit hard to start in the morning. I think it just need a service, change spark plug, fuel filter...etc.
anyway.. since I have no experince on toyota,.. and carby cars.. I need some advice. what kind of mod can I do...? something for performance and also won't cost too much!
I've seen ppl put twin carby on it. how much will that cost? is it hard to do? or just direct fit?
anything else that won't cost too much to mod???
Chris_RA60
Ballarat
Re: Just brought a 1980 Celica, then what do I do now? Wed, 05 June 2002 06:25 Go to previous messageGo to next message
For a start, when you drive it around, take it easy (don't fang it too much), check how much oil/water/fluids it's using. Check this constantly. Keep records of the petrol you put in, so you can check if your guages work properly
Re: Just brought a 1980 Celica, then what do I do now? Wed, 05 June 2002 10:00 Go to previous messageGo to next message
Then once your sure its not going to blow up...then you have competitions with yourself trying to save money by using the least amount of fuel.
Put all the savings aside and get a better engine! Smile
But seriously, do the usual things, like change the oil, the plus and stuff. If you want, run it on 98RON fuel and wind some more ignition advance into it.
Allan
Re: Just brought a 1980 Celica, then what do I do now? Wed, 05 June 2002 10:05 Go to previous messageGo to next message
electronic ignition would be the first thing i would fit to a stock RA40 if you grab all the bits from an RA60 the guts of the dizzy swaps over and the rest should just bolt up! a good exahust is a start the earlyer non polution manifolds with the twin outlet are better then the celica single exit item but it then is technicly unroadworthy as your losen the EGR system and the later model carby
but for starters go for electronic ignition and make shure the cold air flap in the aircleaner is working with a good tune it should go much better
Welcome to the *A4* Series family, a good choice Smile
Allan
Re: Just brought a 1980 Celica, then what do I do now? Wed, 05 June 2002 10:11 Go to previous messageGo to next message
OMG...Allan didn't tell you to gas the bitch!
Allan
Re: Just brought a 1980 Celica, then what do I do now? Wed, 05 June 2002 10:54 Go to previous messageGo to next message
well we shal see how a GAS 5M gos agenst a stock 5M-E at the dyno day hopefully Smile
Allan
Re: Just brought a 1980 Celica, then what do I do now? Wed, 05 June 2002 13:29 Go to previous messageGo to next message
Nice, lets see if there is something to the smelly stuff. Razz
Allan
Re: Just brought a 1980 Celica, then what do I do now? Thu, 06 June 2002 01:04 Go to previous messageGo to next message
less smelling of fuels maybe an idea mate hehehe
Allan
Re: Just brought a 1980 Celica, then what do I do now? Thu, 06 June 2002 02:28 Go to previous message
Hahaha, no smelling here... Razz
Previous Topic:spark plugs, are the twin probe ones better...?
Next Topic:t-vis na cams into ze?
Current Time: Thu Nov 19 19:33:40 UTC 2026
Total time taken to generate the page: 0.0095059871673584 seconds
