Toymods » Tech & Conversions » oil cooler on a 20V
bluehachi
September 2005
oil cooler on a 20V Mon, 05 September 2005 08:38 Go to next message
what sandwich plate do i use to fit an oil cooler on a 20V? where from and how much?
also
theres a bolt in the block above the oil press sender unit on the exhaust side on the 20V, is this tapped into the oil system, i figure it is due to its location next to the pump and oil press sender. If it is can i remove the bolt and fit a fitting and use this as my oil feed for turbo?
Matt-AE86
Re: oil cooler on a 20V Mon, 05 September 2005 12:18 Go to previous messageGo to next message
AE82 Oil Cooler Sandwhich plate ? I cant see why that wouldnt fit, and i have heard of people using the oil sender hole for the turbo feed such as monkey with the light blue 4agte..
bluehachi
September 2005
Re: oil cooler on a 20V Mon, 05 September 2005 12:23 Go to previous messageGo to next message
yeah thats putting a T piece in the oil pressure switch. i dont want to do that but i want to know what the bolt is for next to it
domasik
Re: oil cooler on a 20V Tue, 06 September 2005 01:19 Go to previous messageGo to next message
are you after something like this?
http://wtljkane.customer.netspace.net.au/blockex.jpg
this is on a 16v block but i was thinking about using the same setup on my N/A 20v as its alot more compact that the AE92 sandwich plate which fouls my KE side engine mount.
Skaney wrote on Wed, 10 August 2005 18:09
It came with the oil cooler in a kit. But I think you can by them seperate. Has a Thermostat in it, alot of aftermarket ones dont.
I got it through Dr. Drift.
Skaney wrote on Wed, 10 August 2005 20:21
Whole kit was $180 inc hoses, fittings and the cooler.
Look for him on nissansilvia.com
hope that helps
bluehachi wrote on Mon, 05 September 2005 18:38
can u take a photo of this please?
bluehachi
September 2005
Re: oil cooler on a 20V Tue, 06 September 2005 07:40 Go to previous messageGo to next message
yeah thats what im after, dont need the kit as i already have fittings and lines + cooler. just need the sandwich plate.
bluehachi
September 2005
Re: oil cooler on a 20V Tue, 06 September 2005 07:44 Go to previous messageGo to next message
also that bolt.. your block has it also.
http://img397.imageshack.us/img397/8316/blockex4td.jpg
4a-c
Sutherland Shire
Re: oil cooler on a 20V Tue, 06 September 2005 10:22 Go to previous messageGo to next message
An ae92 sandwich plate will foul on the rwd engine mount
hairywally
April 2005
Re: oil cooler on a 20V Wed, 07 September 2005 02:26 Go to previous messageGo to next message
4a-c wrote on Tue, 06 September 2005 20:22
i don't believe the 4ag fwd factory oil cooler sandwich plate fouls on 4ag rwd motor. this setup being used on 4 ae86's, works fine for all of them. have a got pic but cant firgure out how to post.
Skaney
Re: oil cooler on a 20V Wed, 07 September 2005 07:12 Go to previous messageGo to next message
Simon thats my 16v block with the oil cooler.
Im pretty sure Dr Drift can sell you just the sandwhich plate. Has a thermostat too.
I think I remember reading somewhere that the bolt hole you are talking about is a coolant drain?
Flogbag
Sydney (Campbelltown...!)
Re: oil cooler on a 20V Wed, 07 September 2005 10:17 Go to previous messageGo to next message
yes it is a coolant drain plug
bluehachi
September 2005
Re: oil cooler on a 20V Thu, 03 November 2005 07:37 Go to previous message
bumpy.
what i want to know is what is the thread pitch size for the oil filter? i am about to order a sandwich plate and need to know
Previous Topic:SusPension OIL VS GAS
Next Topic:Difference in'S" type & 'T' diff's in sprinters?
Current Time: Sat Nov 21 19:13:20 UTC 2026
Total time taken to generate the page: 0.0095701217651367 seconds
