Toymods » Tech & Conversions » Cutch size for the 4AGE 20v?
Hachi2Muchi
August 2005
icon3.gif  Cutch size for the 4AGE 20v? Mon, 05 September 2005 16:47 Go to next message
hi guys
I was wondering if anyone knows the correct clutch size for a 20v silver which will go into a t50 gearbox?
any help would be great!!
ive been given two choices 215mm and 200mm...
can anyone of these work with my application?
or has enyone bought an aftermarket clutch for a 20v?
thanks again
[Updated on: Mon, 05 September 2005 17:29]
TE72_Turbo
Re: Cutch size for the 4AGE 20v? Mon, 05 September 2005 22:13 Go to previous messageGo to next message
If you're using the original 20V flywheel, then its the 215mm that you need. Only the old bluetop 16V used the smaller 200mm.
Phil
Hachi2Muchi
August 2005
Re: Cutch size for the 4AGE 20v? Tue, 06 September 2005 01:18 Go to previous messageGo to next message
thanks for the help!
the people @ TOYMODS always come through
Re: Cutch size for the 4AGE 20v? Tue, 06 September 2005 04:37 Go to previous messageGo to next message
you will need to check that you get the correct release bearing too.
Take the release bearing out of the T50 gearbox and into the clutch shop when you get your clutch to ensure you get the correct replacement one.
monkeymajik
Re: Cutch size for the 4AGE 20v? Tue, 06 September 2005 05:00 Go to previous messageGo to next message
Could an incorrect release bearing still go together but prevent the clutch from disengaging at times?
TE72_Turbo
Re: Cutch size for the 4AGE 20v? Tue, 06 September 2005 09:01 Go to previous messageGo to next message
If they give you a FWD bearing, you won't be able to fit it to your bearing carrier at all from memory.
Hachi2Muchi
August 2005
Re: Cutch size for the 4AGE 20v? Tue, 06 September 2005 16:18 Go to previous message
hrrmm....
thanks for that guys
ill see how i go
Previous Topic:Whats the standard compression of a 3tgte
Next Topic:Bolt-in tachometer question
Current Time: Sun Oct 25 05:45:22 UTC 2026
Total time taken to generate the page: 0.0086429119110107 seconds
