Toymods » Tech & Conversions » 4agze No spark please help
ocase
August 2005
4agze No spark please help Tue, 06 September 2005 05:00 Go to next message
I got done installing a 4agze in an 85 GTS but I'm not getting spark. I get *some spark here and there but nothing consitent. Any ideas?
Re: 4agze No spark please help Tue, 06 September 2005 07:47 Go to previous messageGo to next message
more information??
thoughts:
- wiring
- timing
- ignition leads
- coils
- ingitior
- ambiance
- profit
- it was touched by His noodly appendage
ocase
August 2005
Re: 4agze No spark please help Tue, 06 September 2005 19:01 Go to previous messageGo to next message
THE WITZL wrote on Tue, 06 September 2005 17:47
more information??
thoughts:
- wiring
I'm pretty sure that I did the wiring correctly. I have one doubt however. The heat sink, distrubitor noise filter. A B-O wire (power) comes out of it along with a W-B wire (usually ground) it goes to the 4agze fuse box. but I cant find it on any wiring diagram so I took a guess and grounded the W-B wire.
- timing
I figure even if timing was off shouldnt it at least spark?
- ignition leads
I'm getting power
- coils
Coils are getting power and there is a slight change in voltage in the signal wire. I measured it to be about .2 volts. Normal?
- ingitior
I am getting power to the igniter and it is sending pulsers.. .2 volts though.
- ambiance
wat?
Re: 4agze No spark please help Tue, 06 September 2005 22:02 Go to previous messageGo to next message
- wiring...
noise filter, or modern day condenser. W-B is earth, B-O is ignition power.
- ignition leads...
test with ohmmeter. Should be from 3k-8k ohm
- coils...
this suggests coils are working, maybe
- ignitor...
ok, good.
- ambiance...
you have to set the right mood.
wiso
Re: 4agze No spark please help Tue, 06 September 2005 22:04 Go to previous messageGo to next message
another good question anyone would need to help you answer... is it a distributor model, or is it a crank angle sensor and coil packs?
wiso
Re: 4agze No spark please help Tue, 06 September 2005 22:07 Go to previous message
I fitted up a crank angle sensored model to my old mr2, I wasn't really getting spark, all mine was turned out to be the connections in the plug on the CAS weren't really tight and they weren't contacting properly, I squeezed the pins together and it was fine.
Previous Topic:7MGTE probs...
Next Topic:tubro requirements??
Current Time: Fri Nov 20 16:01:11 UTC 2026
Total time taken to generate the page: 0.0064489841461182 seconds
