Toymods » Tech & Conversions » AE82 rear calipers fit jap spec rear discs?
Hachi2Muchi
August 2005
AE82 rear calipers fit jap spec rear discs? Tue, 06 September 2005 16:27 Go to next message
as above
will AE82 rear calipers fit jap spec rear discs?
any advice will be helpful
thanks toymoderz Smile
Scorpion
Menai area of Sydney
Re: AE82 rear calipers fit jap spec rear discs? Wed, 07 September 2005 13:11 Go to previous message
Do you have any specs on the Jap spec discs ?
eg.
diameter of disc, height from inner disc surface to outer face where wheel mounts onto it, thickness of disc, diameter of survace where wheel bolts on ?
Check the catalogue at www.dba.com.au to compare disc sizes.
If you get a match then the parts should be interchangeable, including calipers.
Previous Topic:Can I use Manual Transmission Oil in LSD?
Next Topic:I need a TPS for a 3TGTE, what'll Fit??
Current Time: Fri Nov 20 17:26:47 UTC 2026
Total time taken to generate the page: 0.02000093460083 seconds
