Toymods » Tech & Conversions » Air Filter for 4-AFE
SpecialK
Townsville
August 2005
icon2.gif  Air Filter for 4-AFE Tue, 06 September 2005 23:25 Go to next message
Hey I own a stock Ae92 Corolla with a 4-AFE and I am thinking about fitting an air filter. What are the advantages/disadvantages of different types of aftermarket air filters and which one would be best for my engine?
rthy
Melbourne - NthSubs
Re: Air Filter for 4-AFE Wed, 07 September 2005 02:29 Go to previous messageGo to next message
get a pannel filter for $30 at repco, or a cheap pod filter for $30 also from supercheap
i put a pod filter on a 4afe and it sounded pretty heKtiC when accelerating to 6100rpm (rev limit) Rolling Eyes
only put a pod if u wanna make some fully sick sounds.... there is no real gain with a 4afe unless u get some extractors or exhaust but might as well get a 4age
drift86levin
brisvegas
Re: Air Filter for 4-AFE Wed, 07 September 2005 04:17 Go to previous messageGo to next message
i agree with rthy
no real point..but then again..if you bump up the timing a bit, pod filter or panel filter replacement, and some extractors/exhaust it would go alright! Smile
mideon_696
wollongong
Re: Air Filter for 4-AFE Wed, 07 September 2005 12:31 Go to previous messageGo to next message
replacement performance panel filter for $30 at repco? auto1 want bout $46 or ther abouts for the standard panel for my 7afe!! $30, fuck. 130 for a K & N, lol
rthy
Melbourne - NthSubs
Re: Air Filter for 4-AFE Wed, 07 September 2005 12:47 Go to previous messageGo to next message
yea the pannel filters for k&n cost more than the pods ($50-70)
and i think the pannel filters are ryco not repco but probly the same thing anyways Rolling Eyes
+2hp GAIN!!! (0.05kw+ atw)
SpecialK
Townsville
August 2005
Re: Air Filter for 4-AFE Thu, 08 September 2005 10:51 Go to previous messageGo to next message
I am in the process of getting a 2 inch exhaust system and i was told that extractors would be a waste of time. how would i change the timing? is this a professional job or can a 17 year old do it with a shifter??????
Phrostbyte
Frankston, Victoria
Re: Air Filter for 4-AFE Thu, 08 September 2005 14:02 Go to previous messageGo to next message
I slightly modified the timing on my 4K-C to run 98 octane fuel. Quite simple really, fill your tank with 98 octane, start your engine, undo a bolt right next to your dizzy, then slowly turn your dizzy (you will hear your idle speed increase, this can be turned down again with the idle screw), keep going until you hear your engine start pinging (exactly what it sounds like hhahah), then turn it back a bit.
Then give it a test drive, giving it all the thrashing you can give it. If you hear pinging, turn it down a bit again, if you don't, you've successfully modified your timing for 98 octane fuel and you should notice a slight power increase...
Kev.
Re: Air Filter for 4-AFE Thu, 08 September 2005 17:37 Go to previous messageGo to next message
Phrostbyte wrote on Fri, 09 September 2005 00:02
Kev.
i recommend you don't do that Wink
set timing to factory specs with a timing light.. then if you feel you want to go more, put an extra 2 degrees in at a time. drive up a steep hill at full noise and lower in the rpm range it will be more likely to ping...
easier to just leave it standard or near standard..
4AG stock exhaust manifolds are not bad. no point getting extractors if it is reasonably stock.
as for filters.. the best one is a clean one. no need to go crazy with pods or crappy K&N's,, just get a clean paper filter element and it will be more than you need.
Phrostbyte
Frankston, Victoria
Re: Air Filter for 4-AFE Fri, 09 September 2005 02:00 Go to previous message
oldcorollas wrote on Fri, 09 September 2005 03:37
True that, now that I think about it, I didn't care if the 4kc so much as detonated, if you want your engine to last, do what oldcorollas just said Wink
Kev.
Previous Topic:Custom Interiors
Next Topic:Engineering in Mel
Current Time: Tue Sep 15 03:19:24 UTC 2026
Total time taken to generate the page: 0.0093300342559814 seconds
