Toymods » Tech & Conversions » Urgent advice needed: Spray painting
myTA22
Urgent advice needed: Spray painting Sun, 29 December 2002 08:12 Go to next message
Hi everybody, I need some super urgent advice. I am about to leave to spray my Brother in Laws Datsun 1600. We are spraying a metallic gunmetal grey. I know that we need to spray the colour, tack ragging between each coat and then on the final coat don't tack rag and leave the metallic dust on there. Then pretty much straight away we spray the clear coat. I know we spray a few coats without tack ragging, the final coat we leave and in two or three weeks time we 2000 wet and dry and then polish it. BUT, what are peoples opinions about the final dilution of the last coat of clear? Some say make it really dilute i.e. more thinners than clear, others say spray same dilution as preceding coats. What are peoples opinions on this? and how does the preceding information about the colour coats etc sound?
Thanks for your help and advice
Daniel
riceboy
Japan
Re: Urgent advice needed: Spray painting Thu, 02 January 2003 09:31 Go to previous message
I hope this is of some help. I am not a qualified spray painter but i have airbrushed for many years and have worked with spray painters. Alot of advice i have been given and adhere to myself regarding clear coats is to start the ratio about 70:30 thinners:lacquer (depending on the lacquer. Currenlty i am starting a bit thinker as the lacquer seems to be designed for colder climates and i live in stinking hot Brisbane). Hit the car with 2 coats of that mix then thin each coat as you go (2 x 80:20 then 2 x 90:10) until you are mostly spraying thinners. This gives the finish a much smoother feel and better gloss. Also to give the finish a much deeper look don't wash the pot out after you apply the final base coat but mix the clear in the pot so there is a thin mix of gunmetal grey with the clear. This will still spray on clear (provided you didn't mix too much base coat with it). I gives the metallic a deeper look. Also be sure to use high gloss thinners and not general purpose thinners to get a better finish. This is all assuming you are using acrylics as that is all i use.
As for your base coats and general prep. That sounds fine i guess. I never tack rag between coats myself but I see different approaches here so if you have been recommended that way the go with it.
The experts make painting look easy but it isn't so best of luck with it. I am about to embark on respraying my Sprinter...
Previous Topic:finding a LSD?
Next Topic:unleaded filler neck on pre-unleaded car....HOW?
Current Time: Mon Jun 15 17:22:36 UTC 2026
Total time taken to generate the page: 0.027625799179077 seconds
