Toymods » Tech & Conversions » 4agze into ke-70 dash wiring
love ke70
September 2005
4agze into ke-70 dash wiring Wed, 07 September 2005 08:11 Go to next message
hey guys
im lookin at putting a 4agze into my beloved ke70 corolla. I have read alot of sites about things like this, and having already done an engine swap, 4k-c to a 4k-c im of the belief i should be able to do this without too many tears. my main issue is will my dash and all of those bits and peices, ie tacho, speedo, temp gauge, will they all still work? or will it depend on my wiring, how will i wire all this in, will i require a whole load of aftermarket gauges
also wats a good strong box i could run??
thanx peeps
sideshow
Re: 4agze into ke-70 dash wiring Wed, 07 September 2005 09:26 Go to previous messageGo to next message
well tacho will need a tacho booster
temp is fine if u bolt in the temp sender from the orig eninge
same goes with oil light
alternator wiring needs redoing as the 4agze has internal reg and ke30 has external so wiring needs to be modified on car loom
speedo just run cable to std rwd gbox or whichever box u use
love ke70
September 2005
Re: 4agze into ke-70 dash wiring Wed, 07 September 2005 10:11 Go to previous messageGo to next message
ok, sorry but i dont understand what ur getting at with the alternator??
and what u mean a tacho booster?
jasonp1977
Re: 4agze into ke-70 dash wiring Wed, 07 September 2005 10:23 Go to previous message
you dont need a tacho booster if you mod the tach driver board in the cluster. Only takes two resistors and a capacitor to make it work perfectly. I've done the same thing to my AE71 4agte running GZE electronics...
the guide for the AE86 dash is here:
http://www.rollamods.com/tech/ae86gzetacho.pdf
The AE71 tacho board is a little different but the component values are the same.
Previous Topic:megasquirt wiring question
Next Topic:rear axle
Current Time: Fri Nov 20 15:51:28 UTC 2026
Total time taken to generate the page: 0.0058469772338867 seconds
