Classifieds » Engines, Accessories and other Mechanicals » 2TGEU, All EFI gear, 3T crank Turbo manifold
filthman
Heathmont, Melbourne, Vic
2TGEU, All EFI gear, 3T crank Turbo manifold Wed, 07 September 2005 10:53 Go to next message
I was gathering parts to build a 2TG/3TGTE Hybrid, but due to a change of plans I'm considering selling it.
I'm not interested in making a profit, just getting back some of what i spent.
2TG Engine (261 head)- $200
(I've never had it running, the head it currently off. I was planning on rebuilding it.)
All EFI gear inc. - $300
- ECU
- Intake manifold, plenum & throttle body
- Fuel rail & injectors
- Air flow meter
- Electronic Dizzy
- Cut loom (two ends, anyone half mechanically minded should be able to join it up)
(I wont seperate the EFI gear because without one bit the rest is not worth much.)
Solex carbies on manifold - $100
(One lug is broken off manifold, so make an offer)
3T crank - $100
3TGTE turbo manifold - $100
T50 - $100
Or make an offer!! I can get pics of everything if you have to have them.
All funds to go towards the 13B going into my KE35 with LPG Laughing
lilcrash
ipswich queensland
Re: 2TGEU, All EFI gear, 3T crank Turbo manifold Wed, 07 September 2005 19:35 Go to previous messageGo to next message
does the dizzy hit the fuel rail on your efi setup???
yrhkira
June 2005
Re: 2TGEU, All EFI gear, 3T crank Turbo manifold Thu, 08 September 2005 02:09 Go to previous messageGo to next message
PM sent for Solexes.
Regards
Rodger
bunkyT18
Pilbara
Re: 2TGEU, All EFI gear, 3T crank Turbo manifold Thu, 08 September 2005 02:11 Go to previous messageGo to next message
What condition are the solex carbs in? I'm interested in them and the manifold so please send pics to admantombs@yahoo.com
Buster
Re: 2TGEU, All EFI gear, 3T crank Turbo manifold Thu, 08 September 2005 06:42 Go to previous messageGo to next message
You have PM
Buster
Re: 2TGEU, All EFI gear, 3T crank Turbo manifold Fri, 09 September 2005 08:24 Go to previous messageGo to next message
I'll take that EFI set up please ! PM has been sent!
hurricane
geelong
August 2005
Re: 2TGEU, All EFI gear, 3T crank Turbo manifold Sat, 10 September 2005 22:49 Go to previous messageGo to next message
is the 2TG Engine complete. if not whats missing.
filthman
Re: 2TGEU, All EFI gear, 3T crank Turbo manifold Sun, 11 September 2005 05:36 Go to previous messageGo to next message
yrhkira: pm sent - carbies are complete with airfilters.
lilcrash: not sure if the dissy hits the manifold. Its the original equipement but I haven't trail fitted it to check.
hurricane: yes the engine is complete.
I can sell you the complete 2TG engine package with 261 head, T50 'box, starter motor, alternator, EFI setup as detailed above, 3T crank, flywheel (unknown weight), clutch (unknown condition as its still attached to the engine), and either standard exhaust manifold or turbo manifold.
At the moment the bottom end is assembled, the head has been removed but it hasn't been disassembled.
All you would need to do is rebuild the engine with flycut 3T pistons, and join up / rewire the loom and you've got a 1800 DOHC engine for you Celica or Corolla.
As mention above I also have the 3TGTE turbo manifold. While rebuilding chuck in a set of 3TGTE pistons, modify the intake manifold, run your oil lines, and you've got a 3TGTE with 2TG head.
I should have clarified this earlier. If I don't have any interest in the engine then I'll keep the EFI setup and rebuild it. An engine with no intake is no good to me.
Buster
Re: 2TGEU, All EFI gear, 3T crank Turbo manifold Sun, 11 September 2005 08:36 Go to previous messageGo to next message
If however you do sell the engine to some one who wants to runs carbies, I would very much like that EFI Gear !
newbien
adelaide
August 2005
Re: 2TGEU, All EFI gear, 3T crank Turbo manifold Mon, 12 September 2005 01:12 Go to previous messageGo to next message
could the 3tgte turbo manifold be bolted onto a 3tc???
ae71 kid
melbourne
August 2005
Re: 2TGEU, All EFI gear, 3T crank Turbo manifold Thu, 15 September 2005 04:18 Go to previous message
you have a PM, VERY INTERESTED
Previous Topic:TOYOTA CROWN 1UZ & BOX **PRICE DROP**
Next Topic:7MGTE motor... complete
Current Time: Tue Oct 20 19:02:27 UTC 2026
Total time taken to generate the page: 0.022275924682617 seconds
