Toymods » Tech & Conversions » 1GGTE into a 4A-C powered Tercel, possible?
tercelboy
Townsville, Queensland
1GGTE into a 4A-C powered Tercel, possible? Sun, 29 December 2002 12:16 Go to next message
Was just wondering what (if any) sort of engine mounts need to be made to fit a 1GGTE into a 4A-C powered car. I seen a Sprinter with one in it and I assume you would need to have some new mounts fabricated to make it fit. How hard? How much?
I am looking at putting a 1GGTE into a Tercel (with supra/celica box and new diff) instead of what everyone else seems to be doing which is put a 4A-GZE into a Corolla. (I like to be different, hell, I own a Tercel and have modified it thats different enough). The 4A-C is not only long in the tooth but worn out and is getting beaten by smokey old 1600 Gemini's. Also I can get another Tercel for about $800 and build it up. I will also need to convert the previously front wheel/all wheel drive setup the Tercel has by putting a new diff in it (for rear wheel drive). What measurement should I take of the old box and tunnel to see what would fit? What sort of diff do you recommend?
Any help would be great.
tercelboy
Re: 1GGTE into a 4A-C powered Tercel, possible? Sun, 29 December 2002 12:19 Go to previous messageGo to next message
Not saying everyone puts a GZE into a corolla, I don't wont to offend anyone.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon13.gif  Re: 1GGTE into a 4A-C powered Tercel, possible? Sun, 29 December 2002 13:30 Go to previous messageGo to next message
This is not the easiest conversion you can undertake. And at the end of the day, the 1G-GTE is too heavy for a Tercel. Your car will be front heavy and won't handle very well.
Why not try a 4E-FTE out of a Starlet GT Turbo?
tercelboy
Re: 1GGTE into a 4A-C powered Tercel, possible? Tue, 31 December 2002 03:38 Go to previous messageGo to next message
A Tercel is a very similar size to a Sprinter, as a mater of fact the engine bays look very similar. The type of Tercel I am talking about is a 1984 Toyota Tercel 4WD, they are similar to the Toyota Corolla 4WD of the 1990's but are not full time 4WD (FWD/4WD). The motor is mounted conventionally aswell which would make it easier. I might post some pics not many people know what a Tercel is they just mistake them for the old Subaru 4WD wagon (I have a big TOYOTA sticker on the back of mine).
IRA11Y
Club Member
Re: 1GGTE into a 4A-C powered Tercel, possible? Tue, 31 December 2002 03:43 Go to previous messageGo to next message
I take it youll be doing away with the 4WD then?
4x420v
Penrith
Re: 1GGTE into a 4A-C powered Tercel, possible? Tue, 31 December 2002 05:29 Go to previous messageGo to next message
atleast they confuse ur car with a subaru,they confuse mine with a TERCEL!!!!
tercelboy
Re: 1GGTE into a 4A-C powered Tercel, possible? Tue, 31 December 2002 05:52 Go to previous messageGo to next message
Yes doing away with the 4x4 and dropping and supra/celica diff into it if I can and just have rear wheel drive (will require new diff and tail shaft/resize aswell I guess).
And I am not saying that knowone knows what a Tercel is but I have a problem (up in north queensland) with it being called a subaru. Atleast they keep yours in the family when they call it something different.
RA28
Re: 1GGTE into a 4A-C powered Tercel, possible? Tue, 31 December 2002 07:28 Go to previous messageGo to next message
Dude, you should try to keep the 4WD perhaps, I mean, what's the tercel without 4WD? a big corolla (or maybe sprinter if you make it RWD)
My choice would be as much power as the drivetrain can handle, maybe a 20V? a 4WD revving to 8500 would be alotta fun!!
I think a 1G would kill the 4wd pretty quick Sad
Tim
Nark
Cabramatta, NSW
icon2.gif  Re: 1GGTE into a 4A-C powered Tercel, possible? Thu, 02 January 2003 00:02 Go to previous messageGo to next message
I know the Tercel you're talking about... The 1G-GTE is not something I recommend in a Sprinter either... Too heavy for such a little car.
It's OK if you only plan on driving the car only in a straight line. Well, if you do the conversion, you wouldn't have too much of a choice... Wink
I'd recommend (in order of difficulty) a 4E-FTE, 20V 4A-GE, 4A-GZE, or 3S-GTE.
Keeping the 4WD is a big no-no if you're going for big power. The Tercel gearbox would prolly have trouble keeping together behind a 20V.....
RA28
Re: 1GGTE into a 4A-C powered Tercel, possible? Fri, 03 January 2003 05:02 Go to previous messageGo to next message
sorry, didn't realise the gearbox was that weak...
Tim
Jason
Re: 1GGTE into a 4A-C powered Tercel, possible? Fri, 03 January 2003 06:01 Go to previous message
Tercels generally have a habit of chewing the synchros in first my big sys had one and she did a box and i did a box
Previous Topic:turbo noise
Next Topic:..::4a-gze came from?...........::..
Current Time: Sun Oct 25 09:36:26 UTC 2026
Total time taken to generate the page: 0.094476938247681 seconds
