Toymods » Tech & Conversions » few KE70 cable to hydraulic clutch conversion questions
Phrostbyte
Frankston, Victoria
few KE70 cable to hydraulic clutch conversion questions Wed, 07 September 2005 15:56 Go to next message
Hey peeps,
After an hour searching the forums I found a few things, but not exactly what I needed. I'm a noob and a half when it comes to things like this... Anyway. I have myself an st162 master cylinder, an AE71 pedal box, some clutch line and an AE71 slave cylinder.
Razz - Number one question is how doest the pedal link up to the master cylinder pushrod?
Razz - Number two is does there need to be some sort of return from the slave back to the master? (I see two outlets on the slave but only one on the master).
Razz - Number three is where exactly to mount the master cylinder on the firewall? Should I use maybe one bolt hole that is originally there and then drill the others, or start fresh or what?
Cheers fellow toymodders,
Kev.
Re: few KE70 cable to hydraulic clutch conversion questions Wed, 07 September 2005 15:58 Go to previous messageGo to next message
best idea is to look at someones AE71, since it has hydraulic from factory and is basically a KE70 anyway.. that should answer all your questions..
Phrostbyte
Frankston, Victoria
Re: few KE70 cable to hydraulic clutch conversion questions Wed, 07 September 2005 16:01 Go to previous messageGo to next message
lol I've got a day off tomorrow and planned to get the 4k out and 4age in in the day, but want to get the clutch all set up first and dont exactly have anyone with an ae71 living within 147km of me Confused
Anyone maybe got some pics?
Kev.
September_Squall
Melbourne, Australia
March 2005
Re: few KE70 cable to hydraulic clutch conversion questions Thu, 08 September 2005 01:55 Go to previous messageGo to next message
I'd have used a TE72/AE71 master cylinder (wait, I did lol).
Shocked There is a depression in the firewall the shape and size of the TE72 master cylinder flange, just not drilled from factory as KE70 is cable clutch. My AE71 pedal box had a hole drilled through it, where a pin could be inserted through a two-pronged bracket on the master cylinder pushrod and through the clutch pedal sandwiched between.
Shocked There's no return to the master cylinder, the second port is for the bleed valve noob! lol
Shocked see above
Hope this helps.
Phrostbyte
Frankston, Victoria
Re: few KE70 cable to hydraulic clutch conversion questions Thu, 08 September 2005 02:47 Go to previous message
Cheers man Very Happy
Previous Topic:Sync and reference spark+injection timing
Next Topic:Overhauling/fixing fuel pumps
Current Time: Fri Nov 20 14:31:53 UTC 2026
Total time taken to generate the page: 0.0050110816955566 seconds
