Classifieds » Parts Wanted » JZX81 1JZ Igniter and/or mounting plate
BabyZ
Armidale
JZX81 1JZ Igniter and/or mounting plate Thu, 08 September 2005 00:05 Go to next message
My JZX81 half cut came with a Soarer igniter. It works fine, but doesn't bolt up very neatly to the base plate.
So if anyone has a spare one, or even just the metal bracket that it screws to, that would be great.
I have the base plate that bolts to the firewall, I just need the other bracket that goes between the plate and the igniter.
Maybe someone needs a soarer one and can swap??
Edit: Maybe a picture would help clarify:
http://img368.imageshack.us/img368/5058/igniterbits7gu.jpg
I need the part labeled "Mounting Plate", but from a JZX81. It will obviously look a little different to this Soarer item in the photo, but it screws onto the igniter with Phillips screws, then bolts to the "Base Plate".
I don't need the Base Plate or the igniter.
[Updated on: Sun, 11 September 2005 04:56]
ripfast
June 2005
Re: JZX81 1JZ Igniter and/or mounting plate Thu, 08 September 2005 12:39 Go to previous messageGo to next message
so were u after the jzx81 base plate or soarer 1??
BabyZ
Armidale
Re: JZX81 1JZ Igniter and/or mounting plate Thu, 08 September 2005 12:54 Go to previous messageGo to next message
I need the JZX81 plate.
And I have a Soarer one, if anyone else needs it - although I have no idea what model soarer it is from.
ripfast
June 2005
Re: JZX81 1JZ Igniter and/or mounting plate Fri, 09 September 2005 11:02 Go to previous messageGo to next message
yeah i got one, i have a pic to make sure its the right one. give me your email and ill send it to ya.
BabyZ
Armidale
Re: JZX81 1JZ Igniter and/or mounting plate Fri, 09 September 2005 11:54 Go to previous messageGo to next message
Excellent - good idea to check with the photo, though Smile
email: adam@northnet.com.au
Thanks.
BabyZ
Armidale
Re: JZX81 1JZ Igniter and/or mounting plate Sun, 11 September 2005 05:03 Go to previous messageGo to next message
I'll add a picture of what I need to my first post.
It might clarify things a little better than my bad description Rolling Eyes
BabyZ
Armidale
Re: JZX81 1JZ Igniter and/or mounting plate Wed, 14 September 2005 23:05 Go to previous messageGo to next message
Hmmm ... this might be harder to find than what I thought.
Anybody?
ripfast
June 2005
Re: JZX81 1JZ Igniter and/or mounting plate Wed, 14 September 2005 23:07 Go to previous message
make up some straps to hold it down. that wouldnt be to hard
Previous Topic:Wanted: RA23 parts
Next Topic:4x 7mgte or pre'89 3sgte injectors
Current Time: Sun Nov 1 02:29:59 UTC 2026
Total time taken to generate the page: 0.0071489810943604 seconds
