Toymods » Tech & Conversions » question about my compression results
jackel
question about my compression results Thu, 08 September 2005 06:05 Go to next message
just did a compression test and the results are as following
1 181
2 165
3 160
4 172
after putting oil in spark hole about 3 drops
1 189
2 170
3 170
4 180
Tis screwed is it not
Car is a st141 toyota corona
2L 2s-c
Re: question about my compression results Thu, 08 September 2005 06:09 Go to previous messageGo to next message
To me that means the rings are fine but the valves aren't sealing 100%.
You did do it warm didn't you?
And does it matter?
Isn't the T going in soon?
Re: question about my compression results Thu, 08 September 2005 06:48 Go to previous messageGo to next message
doesn't look that bad at all.. what is spec? 180?
FKN16V
NSW, East Coast
Re: question about my compression results Thu, 08 September 2005 07:00 Go to previous messageGo to next message
I personally dont think the compression results are a problem.
10psi difference might seem like alot, but from wat i see across the many forums i attend, 10psi is acceptable.
Steve
jackel
Re: question about my compression results Thu, 08 September 2005 16:39 Go to previous message
i thought my compression would of been all over the chart and not over 100 Razz
just found my engine manual it says
nominal 1178kPa
minimum 880kPa
1 bar = 100kpa
189 = 1300
170 = 1200
170 = 1200
180 = 1250
PSI .. kPa
i think thats calculatored around right?
Very Happy Very Happy
sweet my engine is running above average
with the 3t-gteu i still need a couple of minor things but i need someone to do the wiring i think i'm missing some of it Confused
[Updated on: Thu, 08 September 2005 16:41]
Previous Topic:Photos of coilover components/mockup- T3 camberplates/hats, King Springs, Koni sleeve kit
Next Topic:3SGTE TVIS question
Current Time: Tue Oct 13 18:05:05 UTC 2026
Total time taken to generate the page: 0.059753894805908 seconds
