Toymods » Tech & Conversions » 3SGTE TVIS question
-=DV=-
Newcastle, NSW
3SGTE TVIS question Thu, 08 September 2005 12:29 Go to next message
gday i was just wondering if any1 knew @ what rpm does the TVIS open with the 1st gen 3SGTE (st165), ive noticed with mine that it will reach full boost (10-12 psi) at about 2700~ rpm and it starts pulling a bit...but once it hits 3100-3200 rpm it just screams and rips ur arms out (bit of an exageration but ya get wat i mean), if this is about the time the tvis opens then it seems to me that its restricting flow for a little too long and id be looking into a way toget it opening earlier without doing away with it all together?
RWDboy
Re: 3SGTE TVIS question Thu, 08 September 2005 15:06 Go to previous messageGo to next message
Doubt it'd be restricting flow for too long unless you have changed cams/head work? I mean, yeah I suppose changing the boost might make a very slight difference but I wouldn't worry about it if it was my car.
Just my 2 cents!
SW20R
Re: 3SGTE TVIS question Thu, 08 September 2005 15:32 Go to previous message
I've tried both on and off
makes no real difference dyno proven.
I still had a nice and flat rising curve.
If you disable the function it will most likely be just a placebo effect. but keep it the way toyota engineered it Wink
[Updated on: Thu, 08 September 2005 15:33]
Previous Topic:question about my compression results
Next Topic:microtech vs haltech vs anyother eng manage sys
Current Time: Sat Oct 17 03:45:02 UTC 2026
Total time taken to generate the page: 0.0070569515228271 seconds
