Classifieds » Miscellaneous » ST18X HALF CUT LEFTOVERS (pics)
warrior
Sydney / NSW
icon2.gif  ST18X HALF CUT LEFTOVERS (pics) Fri, 09 September 2005 04:45 Go to next message
i have a ST182/4 half cut with lots of goodies left over.
it has ABS, climate control, and airbag. among other dash board and engine bay components.
ask away Razz
http://img78.photobucket.com/albums/v293/warrior007/cut.jpg
http://img78.photobucket.com/albums/v293/warrior007/abs.jpg
http://img78.photobucket.com/albums/v293/warrior007/airbag.jpg
Karl
[Updated on: Tue, 13 September 2005 09:33]
-==L=a=N=c=E==-
Brisbane, Queensland
Re: st18X half cut left overs (pics) Fri, 09 September 2005 05:22 Go to previous messageGo to next message
I'm after the relays/fuses where the passenger footwell is.
Also after the little plastic bit on the drivers side vent.
tooch
Bulleen, Melbourne
Re: st18X half cut left overs (pics) Fri, 09 September 2005 10:09 Go to previous messageGo to next message
Hmm wondering if the climate control will work with my ST185...How much for the climate control and the recirc/fresh air button? Or alternatively that whole surround piece?
-==L=a=N=c=E==-
Re: st18X half cut left overs (pics) Fri, 09 September 2005 10:22 Go to previous messageGo to next message
tooch wrote on Fri, 09 September 2005 20:09
you need more then that,
you need, all the sensors, the control box, the blower box.
its a bit conversion job.
Paranoid Android
Sydney NSW
August 2005
Re: st18X half cut left overs (pics) Fri, 09 September 2005 13:07 Go to previous messageGo to next message
I'm after a stabilizer connecting piece that goes from the lower control arm to the stabilizer bar, its about 4 inches in length and has two ball joints
it attaches here, at the arrowhttp://forums.toymods.org.au/index.php?t=getfile&id=14777
do you have the whole ABS system?
also does anyone know how hard it is to convert to ABS brakes
do you have the aircond compressor, and radiator?
Attachment: Picture(96) copy.jpg
(Size: 23.62KB, Downloaded 477 time(s))
warrior
Sydney / NSW
Re: st18X half cut left overs (pics) Fri, 09 September 2005 13:46 Go to previous messageGo to next message
-==L=a=N=c=E==- wrote on Fri, 09 September 2005 15:22
which particular fuses relays were you after ?
i would think that the plastic would go with the climate control !
the whole climate control unit is there, sensors/control box/blower fan/wiring ! should fit on the 185, open to offers on the whole system !
warrior
Sydney / NSW
Re: st18X half cut left overs (pics) Fri, 09 September 2005 13:50 Go to previous messageGo to next message
Paranoid Android wrote on Fri, 09 September 2005 23:07
which control arm do u need it off?
the whole ABS system is there. I have the AC compressor and radiator.
PM sent
Karl
-==L=a=N=c=E==-
Re: st18X half cut left overs (pics) Fri, 09 September 2005 22:46 Go to previous messageGo to next message
warrior wrote on Fri, 09 September 2005 23:46
They are under the glovebox on the passenger side, in the kick panel, all of them if possible. (mainly interested in the foglight relays and fuses and where they go.
Also the nob which is on the drivers side vent, which goes up and down for no air and outside air.
Paranoid Android
Sydney NSW
August 2005
Re: st18X half cut left overs (pics) Sat, 10 September 2005 03:42 Go to previous messageGo to next message
passenger side however i think they are identical,
id take the abs although i dont know how hard it would be to install (at the moment the car i have is non abs)
ill look into it and get back to you
warrior
Sydney / NSW
Re: st18X half cut left overs (pics) Tue, 13 September 2005 09:36 Go to previous messageGo to next message
those things are welded to the control arm. and the cut never had the left control arm. Crying or Very Sad
Paranoid Android
Sydney NSW
August 2005
Re: ST18X HALF CUT LEFTOVERS (pics) Tue, 13 September 2005 14:39 Go to previous messageGo to next message
dude! its not welded to anything, if the control arm is gone then it may be attached to the stabilizer bar.
it is two balljoints connected via a piece of steel rod
two size 12 or 14 nuts hold it in place
been to a few cars at the wreckers and mostly the control arms go and they leave this thing behind
DunkyMonkey
Brissy QLD
Re: ST18X HALF CUT LEFTOVERS (pics) Wed, 14 September 2005 14:55 Go to previous messageGo to next message
stock foglight switch gimme gimme gimme, i mean how much??? and can you try and keep as much of the wiring in the back of the switch!!!
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Wed, 14 September 2005 23:22 Go to previous messageGo to next message
DunkyMonkey wrote on Thu, 15 September 2005 00:55
sorry, but the switch will go with the front bar !
Paranoid Android. I thought you were reffering to the little thing that sticks out of the control arm Embarassed
the cut has one of those little suckers u are after.
Karl
TA-022
Glenmore Park, NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Thu, 15 September 2005 09:18 Go to previous messageGo to next message
just curious calipers? and are they twin piston or better?
Nathan
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Thu, 15 September 2005 13:10 Go to previous messageGo to next message
TA-022 wrote on Thu, 15 September 2005 19:18
Nathan
the calipers are a single piston. they are the same as the ST185, with the larger piston and are rigged for 275mm rotors.
DunkyMonkey
Brissy QLD
Re: ST18X HALF CUT LEFTOVERS (pics) Thu, 15 September 2005 14:09 Go to previous messageGo to next message
awww its a good thing i picked up a fod light switch this morning!!!
da_horse
Melbourne Australia
Re: ST18X HALF CUT LEFTOVERS (pics) Sun, 18 September 2005 07:02 Go to previous messageGo to next message
would you happen to have the power mirror switch? if so how much?
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Sun, 18 September 2005 12:43 Go to previous messageGo to next message
da_horse wrote on Sun, 18 September 2005 17:02
sorry the half cut didnt come with a console which the switch lives in. Sad
da_horse
Melbourne Australia
Re: ST18X HALF CUT LEFTOVERS (pics) Sun, 18 September 2005 14:25 Go to previous messageGo to next message
thats ok mate, thanks anyway Smile
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Mon, 19 September 2005 10:19 Go to previous messageGo to next message
also comes withy the head lights, bonnet, front bar , blinkers etc,
front bar 90% sold to CLG (clint)
bump
Paranoid Android
Sydney NSW
August 2005
Re: ST18X HALF CUT LEFTOVERS (pics) Thu, 22 September 2005 14:19 Go to previous messageGo to next message
- what do you want for it?
id like to look at the a/c stuff if its still available
could you pm me some contact details?
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Sat, 24 September 2005 13:51 Go to previous messageGo to next message
Paranoid Android wrote on Fri, 23 September 2005 00:19
details sent via PM.
bump
Paranoid Android
Sydney NSW
August 2005
Re: ST18X HALF CUT LEFTOVERS (pics) Sun, 25 September 2005 15:53 Go to previous messageGo to next message
almost definate on the air con pending inspection, i need to wait for my wages though (thats why ive put off calling you, if you were wondering)
also, do you have the plastic/carbon fiber trim that goes just under the bonnet?
(bout 140mm long i think, it is under the plactic/carbon fiber bit on the bonnet [not pictured])
edit: would you consider swapping the black bonnet for a white one? its in very good condition
[Updated on: Sun, 25 September 2005 16:00]
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Mon, 26 September 2005 11:30 Go to previous messageGo to next message
Paranoid Android wrote on Mon, 26 September 2005 01:53
yea, when ur ready give me a call, my number was sent via PM.
dont have that plastic thing under the bonnet.
yea, i would swap it if you like, dont see why not Very Happy
Karl
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Mon, 03 October 2005 03:35 Go to previous messageGo to next message
bump
ZOOL@NDER
July 2005
Re: ST18X HALF CUT LEFTOVERS (pics) Tue, 04 October 2005 13:00 Go to previous messageGo to next message
does you have all the panels, headlights, radiator support, etc
tooch
Bulleen, Melbourne
Re: ST18X HALF CUT LEFTOVERS (pics) Wed, 05 October 2005 06:40 Go to previous messageGo to next message
This is kinda random, but I'm after the little rubber grommet that holds the bonnet stay rod thing into the radiator support bar! Really need this Smile
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Wed, 05 October 2005 12:42 Go to previous messageGo to next message
yea, i still have the panels and radiator support if you are interested PM me.
tooch , it didnt have a bonnet rod grommet mate, i think u can get them from toyota for a couple of dollars.
bump !
Paranoid Android
Sydney NSW
August 2005
Re: ST18X HALF CUT LEFTOVERS (pics) Fri, 07 October 2005 10:53 Go to previous messageGo to next message
do you have the black headlight covers?
(ie. the metal painted pieces with the carbon fibre garnish)
i finally got paid Very Happy , so should be right to check out the air cond this week, ill call tomorrow to work out a time
Joe.
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Fri, 07 October 2005 11:11 Go to previous messageGo to next message
hey Joe.
i still have the complete headlight units, but someone has dibs on them at the moment. will let u know if it falls through.
yea mate, just give me a call before you come out.
ps. do you still have my number?
Karl
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Wed, 12 October 2005 11:15 Go to previous messageGo to next message
update
climate control. SOLD
bonnet. SOLD
still available
steering rack
steering column
3sge suspension (I think they may be better than the st184 ones)
radiator support
radiator (single core)
st185 calipers
lots of plastic dash items
SOLD pending payment
front bar. CLG
right/left headlights, control arm. ZOOLANDER
let me know if there is anything else, open to offers.
Karl
[Updated on: Wed, 12 October 2005 11:16]
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Fri, 14 October 2005 12:32 Go to previous messageGo to next message
bump
Puffy
Re: ST18X HALF CUT LEFTOVERS (pics) Sat, 15 October 2005 09:34 Go to previous messageGo to next message
engine bay fuse box if you got it
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Sun, 16 October 2005 00:59 Go to previous messageGo to next message
Puffy wrote on Sat, 15 October 2005 19:34
yea I should have it, is that the one that lives near the battery? I have one thats almost perfect.
Puffy
Re: ST18X HALF CUT LEFTOVERS (pics) Sun, 16 October 2005 01:05 Go to previous messageGo to next message
Thats the one Im after mate - you have PM Very Happy
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Sun, 16 October 2005 01:55 Go to previous messageGo to next message
pm replied
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Wed, 19 October 2005 13:40 Go to previous messageGo to next message
getting rid of the half cut very soon, will strip the parts off it for anyone who wants any.
but if anyone is after a radiator support , now is the time to come and get it.
Karl
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Thu, 10 November 2005 06:50 Go to previous messageGo to next message
bump
celicaboy_2000
Lismore, NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Thu, 10 November 2005 07:57 Go to previous messageGo to next message
You still got the bonnet? do you now have a R/H guard? What sort of condition? Price? These will fit a st162 wont they?
[Updated on: Thu, 10 November 2005 07:59]
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Thu, 10 November 2005 09:23 Go to previous messageGo to next message
celicaboy_2000 wrote on Thu, 10 November 2005 18:57
the bonnet wont fit the st162.
GriZZly
Newcastle NSW
June 2005
Re: ST18X HALF CUT LEFTOVERS (pics) Thu, 10 November 2005 15:03 Go to previous messageGo to next message
im after the fan speed selector/switch thing
how much? ill be in syd on sunday
warrior
Sydney / NSW
Re: ST18X HALF CUT LEFTOVERS (pics) Wed, 30 November 2005 08:15 Go to previous messageGo to next message
GriZZly wrote on Fri, 11 November 2005 02:03
sorry I couldnt catch up GriZZly, was at LUNA PARK Very Happy
bump
StuC
Re: ST18X HALF CUT LEFTOVERS (pics) Sat, 03 December 2005 23:15 Go to previous message
dont suppose you hav the oil cooler setup or did u put that in the 162?i should have asked earlier, cos if u have it, i'll take it.
Previous Topic:WTB: Professional Mountain Bike
Next Topic:SOLD
Current Time: Sat Oct 31 12:48:27 UTC 2026
Total time taken to generate the page: 0.025654077529907 seconds
