Toymods » Tech & Conversions » Clutch slipping
ndgcpr
Pine Rivers QLD
April 2005
Clutch slipping Sat, 10 September 2005 03:23 Go to next message
Hey all,
As most may know i have twin turbo'ed the soarer, but still have the NA clutch and pressure plate, I am working on fixing this asap and i am sure it is slipping and slowly getting worse, as i know have a boost controller and its probably now putting even more power through it.
My question is should i make the boost as low as it goes to prevent extra damage or if it slips it slips and it doesn't matter what my boost is it will still be slipping at the same point?
ndgcpr
Pine Rivers QLD
April 2005
Re: Clutch slipping Sat, 10 September 2005 04:04 Go to previous messageGo to next message
while we are on the point are all slave cylinders the same? if you upgrade your pressure plate do you have to do anything else?
Re: Clutch slipping Sat, 10 September 2005 05:41 Go to previous messageGo to next message
It depends when it slips, it will always slip under the same load, so if your car can put that load on it on low boost, it aint going to mean squat.
And my slave cylinder is the same as my original one.
Turbo_Tim
Townsville
February 2005
Re: Clutch slipping Sat, 10 September 2005 05:46 Go to previous messageGo to next message
Its going to depend on flywheel and clutch plate condition if it will continue to slip.
Solution is to drive sensibly for a while until you get it replaced!
ndgcpr
Pine Rivers QLD
April 2005
Re: Clutch slipping Sat, 10 September 2005 07:06 Go to previous message
yeah i will try but there is a skid pan day tomorrow and i am not going to miss it for something like this Cool
Previous Topic:Suspenion/Wheel question
Next Topic:Info on 1G-GTUE
Current Time: Sat Nov 21 02:41:17 UTC 2026
Total time taken to generate the page: 0.0063631534576416 seconds
