Toymods » Tech & Conversions » Just got a 1G-GTE, need fly wheel, want an upgrade
Airbrushguy
June 2005
Just got a 1G-GTE, need fly wheel, want an upgrade Sat, 10 September 2005 11:28 Go to next message
OK I have finaly got my self a 1G-GTE, it has no fly wheel. It is in a wreck and some #@%&* got to it to do a conversion to manual befor I found it.
Any way the engine seems to be good so I put a deposit on it today and want to find out if there is any light weight flywheels out there for them?
I will be trying to suck a fair bit of power out of this so using my 3T flywheel might not be big enough.
If not I will post in the WTB for a stock one.
hickoz_bro
Re: Just got a 1G-GTE, need fly wheel, want an upgrade Sun, 11 September 2005 10:41 Go to previous messageGo to next message
what i've found as far as any off the shelf aftermarket parts go.. they're as rare as rocking horse shit... i know of about 2 mods... kirks Mines ECU, and a ?HKS? twin charge (or just supercharger) kit,
other then that there's the custom made manifolds etc...
i think you'd be best off sending your flywheel to a engineering workshop and getting it machined off...
Re: Just got a 1G-GTE, need fly wheel, want an upgrade Sun, 11 September 2005 13:50 Go to previous messageGo to next message
[quote title=Airbrushguy wrote on Sat, 10 September 2005 21:28] want to find out if there is any light weight flywheels out there for them?
quote]
what do you mean not big enough??? you mean clutch size??
all you need to do is get get a new one made up to fit the clutch size you want. easy.
or go for aftermarket one like TODA or JUN or HKS or or or.. any of them...
HyDrA
Adelaide, SA
Re: Just got a 1G-GTE, need fly wheel, want an upgrade Mon, 12 September 2005 02:08 Go to previous messageGo to next message
I'm pretty sure you can get aluminium flywheels made up for 1g's without too much bother, just gotta ask a few clutch places (not automotive shops, actual clutch experts).
hickoz_bro
Re: Just got a 1G-GTE, need fly wheel, want an upgrade Mon, 12 September 2005 03:35 Go to previous messageGo to next message
an aluminium flywheel???? wouldn't that be a bit of an overkill? no weight at all, the thing would idle as rough as guts... surely?
HyDrA
Adelaide, SA
Re: Just got a 1G-GTE, need fly wheel, want an upgrade Mon, 12 September 2005 03:54 Go to previous messageGo to next message
Pfft who idles... they have a steel insert for the clutch face to rub against anyway.
Airbrushguy
June 2005
Re: Just got a 1G-GTE, need fly wheel, want an upgrade Sun, 25 September 2005 11:47 Go to previous messageGo to next message
Alloy fly wheel? This could be the go, The OneGee Idle way to smooth anyway, I wouldn't mind a bit of rocking n rolling.
Could be the go.
Got a stock one from a wrecker, got riped off a bit cos he wanted to leave it with the motor, but money talks and that flywheel walked, got the stock clutch with it to thats almost new.
Has anyone ever had an aloy fly wheel made befor, or know what they cost?
Re: Just got a 1G-GTE, need fly wheel, want an upgrade Sun, 25 September 2005 12:57 Go to previous messageGo to next message
The stock flywheel seems to suffice for most people - i'd suggest concentrating on purchasing a suitable performance clutch and pressure plate.
also - an aluminium flywheel isn't going to make the 1G idle rougher - an aftermarket ECU, a larger single turbo and larger injectors will.
cheers,
Charles.
Re: Just got a 1G-GTE, need fly wheel, want an upgrade Sun, 25 September 2005 13:43 Go to previous message
Airbrushguy wrote on Sun, 25 September 2005 21:47
typically start around $5-600, and go up to whatever...
you can get chromoly ones from japan for around $6-800 also..
they are not that expensive..
Previous Topic:3sge wiring problems
Next Topic:GZE MR2 Troubles
Current Time: Fri Oct 16 22:06:56 UTC 2026
Total time taken to generate the page: 0.0052189826965332 seconds
