Classifieds » Miscellaneous » F series Diff Drum to Drum
thetoyman75
Club President
icon10.gif  F series Diff Drum to Drum Mon, 30 December 2002 13:26 Go to next message
Complete Diff assembly from a MX23 Auto.
Measures 1415mm from drum face to drum face ( Perfect width for an RA40 ! )
Toyota RWD 4 Stud Pattern - Open centre with unknown Ratio. (Too lazt to check ! )
$120 ono.
http://www.toymods.org.au/~rod/Parts/Diff.jpg
0416 181 284
celicamad85
Banned member
Re: F series Diff Drum to Drum Mon, 30 December 2002 22:31 Go to previous messageGo to next message
i think you need to mow your lawn Laughing
Pumpkin
Toymods Board Member
Re: F series Diff Drum to Drum Tue, 31 December 2002 02:27 Go to previous messageGo to next message
If it's helps... It's a F312..Pretty sure it's a 4.111, manual I think were 3.9.. Confused
Could be wrong.
Confused
Re: F series Diff Drum to Drum Tue, 31 December 2002 06:48 Go to previous messageGo to next message
F312 is 3.909:1 open centre 7.5", Pumpkin.
CrAiGzEE
south of the big smoke
Re: F series Diff Drum to Drum Tue, 31 December 2002 14:33 Go to previous messageGo to next message
how much difference in ratio is it from a ta23 diff
rod im interested ill talk to ya on icq
thetoyman75
Club President
icon10.gif  Re: F series Diff Drum to Drum Sat, 04 January 2003 02:53 Go to previous messageGo to next message
Thanks Pumpkin/GT, It is a F312 - ie 7.5" 3.909 open centre Smile
Oz Craig,
Mate the RA23 will have a 4.100 Centre (6.7") Not sure how wide the RA23 Diff is I don't have one here to measure. The MX23 Diff is the same width as an RA40 diff tho !
The 3.909 ratio is better suited to a Turbo engine ove a N/A one as it will load the Turbo up more and should in turn bring it on boost sooner Smile
ddeane
PNG
Re: F series Diff Drum to Drum Sat, 04 January 2003 09:13 Go to previous messageGo to next message
Rodney
Is a MX23 an about 76 Mark2 Corona? If so sold!!
Craig
Re: F series Diff Drum to Drum Sat, 04 January 2003 13:27 Go to previous messageGo to next message
It is indeed.
thetoyman75
Club President
Re: F series Diff Drum to Drum Sat, 04 January 2003 15:55 Go to previous messageGo to next message
Craig,
Mate thats exactly what it is out of ! You even got the year right ! Smile
Give me a call if your interested in it.
0416 181 284
TE72_Turbo
Re: F series Diff Drum to Drum Sun, 05 January 2003 02:59 Go to previous messageGo to next message
really? Whats the benefit if of coming on boost a tiny bit earlier in real terms? Surely your acceleration is still hampered by the taller diff ratio enough to negate any earlier spoolup?
thetoyman75
Club President
icon10.gif  Re: F series Diff Drum to Drum Sun, 05 January 2003 05:36 Go to previous messageGo to next message
Diff is Sold thanks Smile
thetoyman75
Club President
Re: F series Diff Drum to Drum Sun, 05 January 2003 05:49 Go to previous messageGo to next message
TE-72 Turbo,
I have every intention of testing out this therory myself once Tina's car is on the raod. However the small twin Turbo's on the 1G may not aid the theory all that well.
Theory suggests that the greater the load on the engine the sooner the Turbo will come on boost and it is supposed to well an truely outway the benefits of the taller gearing. I intend to run bot a 3.7 and a 4.1 (or 4.3 if I can find one) and see the difference personally.
I am aware of one application where the car did not make boost in first gear due to large turbo's when running a 4.1 ratio but after fitting a 3.7 it now generates boost in first quit happily.
One again this is all as I have been told and I am looking forward to testing it all out for myself. It could simply be that the turbo engines are better with a lower ratio (numerically) purely so you don't have to change gears so often ?
TE72_Turbo
Re: F series Diff Drum to Drum Sun, 05 January 2003 11:57 Go to previous message
Fair enough. I'd be interested to hear the results once you've tried both combinations. As you said, you may find minimal result with smaller, early boosting turbos on the 1G, but in the case of my 4AGTE, having a large turbo & 3.7:1 diff ratio results in enough drop in revs between gears to necessitate almost flat shifting to stay within an effective power range. I will be fitting a 4.1:1 in the next week or so Smile
CHeers
Phil
Previous Topic:2S Bellhousing
Next Topic:For Sale : 1ggte Flywheel and TRD Clutch
Current Time: Thu Oct 29 08:03:26 UTC 2026
Total time taken to generate the page: 0.0051259994506836 seconds
