Toymods » Tech & Conversions » T50 - Electronic speedo sensor?
domasik
T50 - Electronic speedo sensor? Sun, 11 September 2005 10:08 Go to next message
does the T50 have an electronic speedo sensor or is it a cable? i know that some AE86's in japan had digital dash's. are there some T50's with electronic speedo sensors or can u plug a sensor in from another gearbox?
im asking because my original plan was to use a W55 and use a W58 electronic speedo sensor so i can use a cluster out of a newer car. but now im going to be using a T50 after all
timottaway
Re: T50 - Electronic speedo sensor? Sun, 11 September 2005 10:18 Go to previous messageGo to next message
its just a cable.
FKN16V
NSW, East Coast
Re: T50 - Electronic speedo sensor? Sun, 11 September 2005 11:08 Go to previous messageGo to next message
domasik wrote on Sun, 11 September 2005 20:08
As mentioned its not electronic in the way your thinking.
The speedo cable runs into the cluster then its electronic even on the analogue clusters.
http://toymods.org.au/Repository/TechDocs/ae86_boo k/body_elec/untitled_scanned_23.jpg
Pin N#7 is the one your after for the analogue cluster.
Im still trying to find the one for the Digital Cluster but no luck yet, cause im mainly lazy.
Hope it helps somewhat.
Steve
domasik
Re: T50 - Electronic speedo sensor? Sun, 11 September 2005 12:04 Go to previous messageGo to next message
so its not going to be possible to hook up a JZA80 cluster after all? Sad
is there like a converter u can buy?
FKN16V
NSW, East Coast
Re: T50 - Electronic speedo sensor? Sun, 11 September 2005 13:03 Go to previous messageGo to next message
domasik wrote on Sun, 11 September 2005 22:04
Im guessing the JZA80 has a electronic speedo and you'll need the gearbox from the same car the cluster came from.
Converter, "i highly doubt it".
Sixworks in Newcastle would be the only people i can think of that would do such a thing but "i highly doubt it"
MAybe some searching and emails will help your cause.
Steve
sideshow
Re: T50 - Electronic speedo sensor? Sun, 11 September 2005 21:50 Go to previous message
its easy to do
i sell electreonic sensors that screw onto the gbox
that send the signal to the dash
if the speedo is inaccurate then u might need a speedo adjuster
theyre about 220 bucks
so in the end it might be about 350 bucks in parts just to get it to read accurately
or u can get a 2nd hand speedo sensopr of the matching gob to save u bit of money
and see how far out the speedo is
anyway i have all the parts to do this and i can calibrate yr speedo too if u want me to
the whole job could end up costing 400 or 500 depending on parts needed
[Updated on: Sun, 11 September 2005 21:51]
Previous Topic:18RGU -> 18RGTEU
Next Topic:AE 86 Battery problem 'pissing me of '
Current Time: Wed Oct 14 09:50:57 UTC 2026
Total time taken to generate the page: 0.045461893081665 seconds
