Toymods » Tech & Conversions » Jumpstarting with a microtech ecu
SIKPUPY
Jumpstarting with a microtech ecu Sun, 11 September 2005 15:06 Go to next message
Having installed the microtech ecu (LT10S) whats the deal, if the battery is flat or I need to jump start someoene, well can I do it ??????
Do I need to use one of those spike things etc etc
any help would be good
Re: Jumpstarting with a microtech ecu Mon, 12 September 2005 00:37 Go to previous messageGo to next message
I've jumped started my car many a time with Microtech ecu.
Never been an issue.
Re: Jumpstarting with a microtech ecu Mon, 12 September 2005 01:15 Go to previous messageGo to next message
ditto - I can't imagine the new ones would prevent a jump start ?
sideshow
Re: Jumpstarting with a microtech ecu Mon, 12 September 2005 10:09 Go to previous message
only prob with them is if yr batt voltage gets below 9 or 10 volts the microtech has a hard time starting the engine
especially if the person who wired it has wired the battery wire not to the battery
for very good voltage i always run the batt wire for a microtech straight to the batt positive not to starter positive or alternator positive
always to batt pos terminal
this way it will eliminate any bad connections or current draw
but if bat is low theres no prob jump startin it just put neg clamp from jumper leads to the engine not to bat terminal this is mainly a safety for surges
Previous Topic:18RGU throttle linkages
Next Topic:adding power steering ae82
Current Time: Sat Oct 24 22:22:13 UTC 2026
Total time taken to generate the page: 0.004457950592041 seconds
