Toymods » Tech & Conversions » 4-AGE Black Cover 20v running too rich?
mylespowell
August 2005
4-AGE Black Cover 20v running too rich? Sun, 11 September 2005 23:00 Go to next message
I have just completed a conversion with a Black Cover 4age 20 valve (into 89 SX). It seems to be running very rich (black smoke on hard accel and black soot on bumper near exhaust exit).
There are no error codes on the ECU, I think I have all the vacuum lines right, has new plugs, air cleaner is ok, tried resetting ecu and I have checked the timing.
Has any got any suggestions to either isolate the problem or solve it?
WiLo
wollongong NSW
Re: 4-AGE Black Cover 20v running too rich? Mon, 12 September 2005 06:24 Go to previous messageGo to next message
is the O2 sensor connected?
187_20v
Re: 4-AGE Black Cover 20v running too rich? Mon, 12 September 2005 07:23 Go to previous messageGo to next message
what oil are u using in the engine
cause in my silver top 20v i had 10w-30w oil or i think it was a lower grade
but when i was running that oil its use to smoke heaps when i plant my foot down or down shift in high rpm
but when i went 2 a higher grade oil gtx3 15w-40w
it doesnt seem 2 do it as often
mylespowell
August 2005
Re: 4-AGE Black Cover 20v running too rich? Wed, 14 September 2005 09:49 Go to previous messageGo to next message
O2 sensor is connected and seems to be working ok.
Running GTX3 oil.
Fuel economy is still good (500k per tank).
The annoying bit is it gives a slight cough every time you bring your foot off the throttle as you pass over hills etc. That is why I though it was running rich at this throttle setting (ie 5% or something)
I take it there is no adjustment for CO2 etc on these?
kingmick
Banned by his request
moved to tamworth
Re: 4-AGE Black Cover 20v running too rich? Wed, 14 September 2005 10:37 Go to previous messageGo to next message
think you will find your oxy sensor is buggered.it is running in wot mode{wide open throttle}.
mick
20VBTSECA
May 2005
Re: 4-AGE Black Cover 20v running too rich? Wed, 14 September 2005 14:59 Go to previous message
was gunna say check your map sensor but not if your getting 500 km's froma tank. you would be getn like 80 and it would sound like a rotary Very Happy
Previous Topic:18rg in a Rx30, a few questions
Next Topic:AE95 SR5 in Ae92?
Current Time: Fri Nov 20 21:36:22 UTC 2026
Total time taken to generate the page: 0.0058279037475586 seconds
