Toymods » Tech & Conversions » ignition for 2t/3tgte
cooter
perth
ignition for 2t/3tgte Mon, 12 September 2005 07:14 Go to next message
hey guys i will be rebuilding a 3tgte soon but am wanting to go the hybrid path of 2tgeu head, injection etc with 3tgte turbo manifold etc on the 3tgte bottom end. i think ive got most of the mechanics sussed but ignition is ??? seeing as how the dizzy from the 3tgte comes out of the head and on the 2tgeu it in the block i have a problem. lol.
so my question is is it possible to use the stock 2tgeu electronic dizzy (88262 external ignitor) setup for a boost application? or will i need to go the coil packs path. i will be running a aftermarket ecu so am wondering if i have to get fuel only (if i can use the 2tg dizzy) or fuel and spark for some sort of coil pack setup.
intended use is a street car with only mild boost( how does 12psi sound?) forgies etc will be the go.
any help and advice is greatly appreciated cause im new to the 3tgte engine.
craig
cooter
perth
Re: ignition for 2t/3tgte Wed, 14 September 2005 07:00 Go to previous messageGo to next message
bump
pheonix83
Devonport Tasmania
Re: ignition for 2t/3tgte Wed, 14 September 2005 11:37 Go to previous message
well.
the 2tg dizzy does not retard on boost.
that said you could lock the 2tg dizzy, and make up a sensor for the harmonic balancer and use an aftermarket computer to retard ignition.
Previous Topic:1JZ-GTE Got Smoke? Please share experiences and solutions
Next Topic:ST162 Interior Fuse Diagram
Current Time: Fri Nov 20 20:34:20 UTC 2026
Total time taken to generate the page: 0.0041089057922363 seconds
