Toymods » Tech & Conversions » unleaded filler neck on pre-unleaded car....HOW?
TE72_Turbo
unleaded filler neck on pre-unleaded car....HOW? Mon, 30 December 2002 23:13 Go to next message
Engineer says I need to fit an unleaded filler neck to my TE72 corolla (T18) now that it has a 4AGZE.
Where the hell do I get a filler neck? Should one from a later unleaded toyota fit??
Thanks in advance
Phil
Darola
Taree, 4h nth of syd
Re: unleaded filler neck on pre-unleaded car....HOW? Tue, 31 December 2002 03:00 Go to previous messageGo to next message
hey there, if its the same as the ae82 rollas cant u just change the head bit, the line to the tank is the same from leaded to unleaded in the rollas, i have to do the same to my rolla with the gze.
good luck
Eddie
(Darola)
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: unleaded filler neck on pre-unleaded car....HOW? Wed, 01 January 2003 03:21 Go to previous messageGo to next message
I managed to do mine fairly easily, if what a bit bodgy.
I cut out a 4-5cm section of filler neck that has the flap in it out of a later model celica, and shoved this into the middle of a 10-12cm section of that really fat filler neck rubber hose.
Then I chopped out a section of my filler neck, approx 4-5cm (obviously nice & close to the filler cap), and shoved the rubber hose with the flap in it so the section of flap replaced the bit I cut out, & the rubber hose becomes a sleeve over the joins. A couple of big hose clamps either end, and if you use old hose & clamps only a celica nut would pick it as being different to standard.
Does anyone understand that? Smile
The best way would be to remove the neck completely from the car & have a flap welded in, but hey, I didn't have a welder at the time.
TE72_Turbo
Re: unleaded filler neck on pre-unleaded car....HOW? Wed, 01 January 2003 06:18 Go to previous messageGo to next message
Do you actually have to have the flap, or is the engineering requirement just to have a filler that is smaller in diameter to prevent you from putting the leaded fuel pump in?
RA28
Re: unleaded filler neck on pre-unleaded car....HOW? Wed, 01 January 2003 07:36 Go to previous messageGo to next message
Just get one from another car that looks like it will fit, I got one from a magna (the first body shape) this fit almost perfectally in my RA28, when cut to lengththat is, remember to get the screw-on cap as well though, I had to go back to steal one!!
Tim.
Re: unleaded filler neck on pre-unleaded car....HOW? Wed, 01 January 2003 10:28 Go to previous messageGo to next message
You can get filler restrictors that can be shoved into a normal sized filler neck that are used when compliancing imports. They're rough as guts, but keep the white coats happy. Another thing to remember - you can't actually buy leaded petrol in Australia any more... oh well, guess they missed that one Very Happy
TE72_Turbo
Re: unleaded filler neck on pre-unleaded car....HOW? Wed, 01 January 2003 13:38 Go to previous messageGo to next message
That's just the kind of thing i'm looking for. Where can you buy them?
Phil
Bugman
Re: unleaded filler neck on pre-unleaded car....HOW? Thu, 02 January 2003 07:54 Go to previous message
i heard bd4's sold something like that..
Previous Topic:Urgent advice needed: Spray painting
Next Topic:fuel pressure
Current Time: Mon Oct 26 13:45:11 UTC 2026
Total time taken to generate the page: 0.0052399635314941 seconds
