Toymods » Tech & Conversions » 3SGTE compression - 140-155?
benmeyer
3SGTE compression - 140-155? Mon, 12 September 2005 10:22 Go to next message
What should teh standard compression on a GenII 3SGTE be? Does anybody know?
TA22-3SGTE
MACKAY
Re: 3SGTE compression - 140-155? Mon, 12 September 2005 10:25 Go to previous messageGo to next message
Just did a compression test on mine yesterday , 175 psi .
Trevor
Hunty
Re: 3SGTE compression - 140-155? Mon, 12 September 2005 11:14 Go to previous messageGo to next message
195 across the board on mine
benmeyer
Re: 3SGTE compression - 140-155? Mon, 12 September 2005 11:42 Go to previous messageGo to next message
175? 190?
A nearby mechanic told me it should be near 150? but then, you can never trust mechanics.
TA22-3SGTE
MACKAY
Re: 3SGTE compression - 140-155? Mon, 12 September 2005 12:13 Go to previous messageGo to next message
I have gen 3 pistons in mine which are lower compression than the gen 2 so the gen 2 will be higher than my 175 psi .
Trevor
Joshstix
Toymods Vice President
Re: 3SGTE compression - 140-155? Tue, 13 September 2005 02:05 Go to previous messageGo to next message
Don't worry too much about the absolute numbers unless they are really low.
Just warm it up, remove the efi fuse, hold the throttle wide open and do you test. Then if the results are all close it should be all good. The BGB quotes a variation of 15psi maximum. When I tested mine it was closer to 70 psi difference between number 3 and all the rest, that's not such a good result Wink
The absolute number you get will be influenced by battery charge, starter condition, obstruction on the intake and exhaust tracts.
benmeyer
Re: 3SGTE compression - 140-155? Tue, 13 September 2005 03:36 Go to previous messageGo to next message
Thanks mate, that was a nice answer.
I got
155
155
150
152
But the engine was cold....
benmeyer
Re: 3SGTE compression - 140-155? Tue, 13 September 2005 04:32 Go to previous messageGo to next message
See the question stems from a starting problem.
The car sometimes takes a bit of effort to start, but then sometimes it is perfect, it doesn't seem to be directly related to warm or cold starts and that's the compression I'm getting.
What else could this be?
Hunty
Re: 3SGTE compression - 140-155? Tue, 13 September 2005 06:45 Go to previous messageGo to next message
battery charge?
benmeyer
Re: 3SGTE compression - 140-155? Tue, 13 September 2005 08:29 Go to previous messageGo to next message
This problem has outlasted 2 of those! Wink
Toobs
Re: 3SGTE compression - 140-155? Tue, 13 September 2005 09:26 Go to previous messageGo to next message
Buggered ISCV?
Hunty
Re: 3SGTE compression - 140-155? Tue, 13 September 2005 12:37 Go to previous messageGo to next message
bad kharma?
Razz sorry mate what about checkin all your grounds? make sure theres no lose ones, starter solenoid? starter motor?
benmeyer
Re: 3SGTE compression - 140-155? Tue, 13 September 2005 21:48 Go to previous messageGo to next message
Good idea mate, but unfortunately, my backyard expertise doesn't extend that far. I'll be taking it in to my mechanic tomorrow.
At the very least, I know it's not compression, so that's one thing.
MR. 2
Parramatta
Re: 3SGTE compression - 140-155? Wed, 14 September 2005 05:25 Go to previous messageGo to next message
how thick is the gasket you are running have you got a lower comp pistons??? these add up i have only 155 in all cylnders. i know my car runs well still, and quite healthy
SW20R
Re: 3SGTE compression - 140-155? Thu, 15 September 2005 00:34 Go to previous messageGo to next message
Here's my results GEN 2 3SGTE from ST185
4th cy - 150
3rd cy - 150
2nd cy - 160
1st cy - 125
WantaTurbo
Re: 3SGTE compression - 140-155? Thu, 15 September 2005 03:13 Go to previous message
Last time mine was done they were 185psi on all cylinders Smile thats for a gen 2 3S-GTE in my st185
Previous Topic:4AGE LOW REVS PROBLEM
Next Topic:Relocation of Petrol Filter MA61?
Current Time: Thu Nov 19 09:00:20 UTC 2026
Total time taken to generate the page: 0.0070669651031494 seconds
