Classifieds » Engines, Accessories and other Mechanicals » Ca18det/ae86 Parts Cleanout, lots of parts!
ae95
Ca18det/ae86 Parts Cleanout, lots of parts! Mon, 12 September 2005 10:46 Go to next message
Toyota:
T18 axles pair - 100
Front tow brackets - 30
Aus calipers pair - 70
middle grill bracket - 25
std gknob - 10
bonnet latch 45
jap clutch slave cyl - 50
charcoal cannister - 25
AE86 antenna - perfect 50
under dash fan unit 30
clutch fan x2 20ea
aus spec overflow bottle - 25
jdm washer bottle - 150
std horn 15
radiator brackets 20 the pair
std aus tailshaft 35
rear seats blue - 150
std struts - 150 the pair (left one may be bent)
Assorted blue/brown interior $ask
turbo outlet pipe x2 20ea
aircon brack with tensioner x3 50 ea
eng/gbox brace 25
power steering bracket w/ tensioner x3 50ea
eng mounts x2 50per pair
turbo oil lines 20ea
inlet manifold bracket 30
a/c pipe 10
t25 seized, partly disassembled, suit rebuild no actuator 100
turbo intake pipe (rubber) 20
coilpack cover 20
timing cover backing plate 15
cam covers 50 the pair
std turbo exhaust manifold w/ clips nuts and gasket 70 ea
heatshield to suit above 30
vacuum cannister 25
turbo outlet pipe rubber join 10
timing cover lower 15
std cam gears 20 the pair
auto flywheel 25
clutchfanx2 50ea
a/c pump x2 120ea
p/s pump x2 90ea
Choony_AE86
Melbourne, South East
Re: Ca18det/ae86 Parts Cleanout, lots of parts! Mon, 12 September 2005 10:49 Go to previous message
dibs the bonnet release
pm me!
do u have the bit that the metal pole that holds the bonnet up lies on?
i think its called a radiator support, the radiator brackets screw into this piece i need.
[Updated on: Mon, 12 September 2005 10:50]
Previous Topic:new dizzy rotor suit charade, sprinter, corona, crown, dyna, hi ace etc.
Next Topic:HKS BOV
Current Time: Sat Oct 24 07:50:16 UTC 2026
Total time taken to generate the page: 0.019937038421631 seconds
